MPI Issues with installing SU2 Parallel on AWS ParallelCluster |
A Roy
Rep Power: 3 ![]() |
I am trying to install SU2 on AWS ParallelCluster (slurm as the scheduler) and the parallel build-from-source on Ubuntu 20.04 refuses to work for me, approaches so far: *ParallelCluster comes with OpenMPI 4.1.5 pre-installed, but using configuring meson with -Dwith-mpi=enabled does not pick it up* As well as the above: 1. Configuring with MPICH from the ubuntu packages does not get picked up 2. Removing the existing MPI using sudo apt-get remove openmpi* and sudo apt-get autoremove, then rebuilding OpenMPI from source does not get picked up Trying any of the above options with -Dcustom-mpi=true and export CC=mpicc, export CXX=mpicxx with meson encounters a problem at ninja build immediately with a cannot find mpi.h error despite the include path being shown by trying mpicc -showme The only option that kind of works is carrying out the above remove steps in 2 then installing OpenMPI with the ubuntu openmpi-bin openmpi-common and libopenmpi-dev packages. With this, -Dwith-mpi=enabled picks up MPI and gets built. However, attempting to run SU2_CFD with mpirun results in the below error: Code:
mpirun: symbol lookup error: /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_pmix_ext3x.so: undefined symbol: pmix_value_load Browsing StackOverflow suggests that the above is due to different mpi versions being used for compile and for build or run...which suggests further that the remove openmpi* options are not doing a good enough job? Any other ideas on how to try and get the mpi version of SU2 built on ParallelCluster or troubleshooting methods? Thank you! |
Parallel execution of SU2 | marco.fossati | SU2 | 15 | June 13, 2024 16:39 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
Installation issues for parallel computation | Akash C | SU2 Installation | 1 | June 21, 2013 05:26 |
A question about HP MPI Local Parallel | nucfusion | CFX | 2 | March 15, 2013 02:07 |
Error using LaunderGibsonRSTM on SGI ALTIX 4700 | jaswi | OpenFOAM | 2 | April 29, 2008 10:54 |
