Mustafa Lone
Rep Power: 0 ![]() |
I ran meson.py using the following command
python meson.py build -Denable-autodiff=true -Denable-directdiff=true -Denable-pywrapper=true -Denable-tests=true Code:
SU2 8.0.0 "Harrier" User defined options enable-autodiff : true enable-directdiff: true enable-pywrapper : true enable-tests : true Found ninja.exe-1.9.0 at C:\su2code\ninja.exe Traceback (most recent call last): File "C:\su2code\externals\meson\mesonbuild\mesonmain.py", line 146, in run return options.run_func(options) File "C:\su2code\externals\meson\mesonbuild\msetup.py", line 294, in run app.generate() File "C:\su2code\externals\meson\mesonbuild\msetup.py", line 185, in generate self._generate(env) File "C:\su2code\externals\meson\mesonbuild\msetup.py", line 247, in _generate intr.backend.generate() File "C:\su2code\externals\meson\mesonbuild\backend\ninjabackend.py", line 553, in generate self.generate_target(t) File "C:\su2code\externals\meson\mesonbuild\backend\ninjabackend.py", line 900, in generate_target elem = self.generate_link(target, outname, final_obj_list, linker, pch_objects, stdlib_args=stdlib_args) File "C:\su2code\externals\meson\mesonbuild\backend\ninjabackend.py", line 3062, in generate_link dep_targets.extend(self.guess_external_link_dependencies(linker, target, commands, internal)) File "C:\su2code\externals\meson\mesonbuild\backend\ninjabackend.py", line 2907, in guess_external_link_dependencies search_dirs, static_patterns) File "C:\su2code\externals\meson\mesonbuild\backend\ninjabackend.py", line 2848, in guess_library_absolute_path trial = CCompiler._get_file_from_list(self.environment, trial) File "C:\su2code\externals\meson\mesonbuild\compilers\mixins\clike.py", line 1036, in _get_file_from_list if p.is_file(): File "C:\Program Files\Python37\lib\pathlib.py", line 1344, in is_file return S_ISREG(self.stat().st_mode) File "C:\Program Files\Python37\lib\pathlib.py", line 1140, in stat return self._accessor.stat(self) OSError: [WinError 123] The filename, directory name, or volume label syntax is incorrect: 'C:\\mingw64\\bin\\..\\lib\\gcc\\x86_64-w64-mingw32\\8.1.0\\libC:\\Program Files (x86)\\Microsoft SDKs\\MPI\\Lib\\x64\\msmpi.a' ERROR: Unhandled python exception This is a Meson bug and should be reported! Code:
C:\mingw64\lib\gcc\x86_64-w64-mingw32\lib (not in the folder 8.1.0) Code:
C:\Program Files (x86)\Microsoft SDKs\MPI\Lib\x64\msmpi.lib Code:
ninja: error: loading 'build.ninja': The system cannot find the file specified. ninja: Entering directory `build' |
Vanessa Chung
Rep Power: 2 ![]() |
Hi, I am getting the exact same error. Did you happen to know what's going on? Thanks!
A problem with compilation of OlaFlow | Mahdi_Kh | OpenFOAM | 4 | January 16, 2023 02:01 |
Error during compilation (python-wrapper) | wimcardoen | SU2 Installation | 1 | March 13, 2022 23:29 |
[foam-extend.org] foam-extend-3.2 compilation on windows | kirmaks | OpenFOAM Installation | 7 | December 3, 2019 20:20 |
Compilation Error (V 1.7.1; Icc 12.1.0, OpenMPI 1.4.3) | floydfan | OpenFOAM Installation | 7 | December 20, 2011 05:56 |
Compilation Error.... | Arnab | Siemens | 4 | September 12, 2004 15:54 |
