Home > Forums > Software User Forums > SU2 > SU2 Installation
SU2 Installation failed
Like Tree1Likes
  • 1 Post By rk1
Old   April 4, 2024, 10:31
Post SU2 Installation failed
rk1
rks231
rk1 is on a distinguished road
Hello guys, I am facing the following issue while installing the SU2; what should I do, I want to use FSI and pywrapper for the python function. Thank you so much in advancd. I follow in the following way;
$ python3.9 -m venv venv
$ source venv/bin/activate
(venv) $ export MPICC=/opt/intel/oneapi/mpi/2021.6.0/bin/mpicc
(venv) $ export MPICXX=/opt/intel/oneapi/mpi/2021.6.0/bin/mpicxx
(venv) $ export CC=$MPICC
(venv) $ export CXX=$MPICXX
(venv) $ pip install --upgrade pip
(venv) $ pip install mpi4py
Requirement already satisfied: mpi4py in ./venv/lib/python3.9/site-packages (3.1.5)
(venv) $ ./meson.py build -Denable-autodiff=true -Denable-directdiff=true -Denable-pywrapper=true -Dcustom-mpi=true
Message: Using mpi4py from /data/home/rashmi/local/SU2/venv/lib/python3.9/site-packages/mpi4py/include
WARNING: extract_all_objects called without setting recursive
keyword argument. Meson currently defaults to
non-recursive to maintain backward compatibility but
the default will be changed in the future.
SU2_PY/pySU2/meson.build:36:2: ERROR: Tried to form an absolute path to a source dir.
You should not do that but use relative paths instead.
To get include path to any directory relative to the current dir do
incdir = include_directories(dirname)
After this incdir will contain both the current source dir as well as the
corresponding build dir. It can then be used in any subdirectory and
Meson will take care of all the busywork to make paths work.
Dirname can even be '.' to mark the current directory. Though you should
remember that the current source and build directories are always
put in the include directories by default so you only need to do
include_directories('.') if you intend to use the result in a
different subdirectory.
wglao likes this.
rk1 is offline   Reply With Quote
Installation error with SU2 - Adjoint cfd-jg SU2 Installation 0 December 18, 2023 07:55
SU2 parallel install build from source failed steadyman SU2 Installation 19 April 25, 2021 17:50
[foam-extend.org] 3.2 Installation in Debian 8.5 jsm OpenFOAM Installation 2 June 19, 2016 11:53
Problems installing OpenFOAM 2.3.0, 1.6-ext and foam-extend 3.0 sam.ho OpenFOAM Installation 35 April 5, 2014 16:31
DeardorffDiffStress turbulence model Zuixy OpenFOAM Running, Solving & CFD 0 November 14, 2011 09:44
