February 15, 2014, 22:48 |
problem in shape optimization test
Yibin Dou
Rep Power: 16 |
hello
I also have problem in runing shape_optimization(tutorial 7 in su2 website). I install the SU2-3.0.000-32-bit-Single-threaded.exe, python 2.6.6,scipy 0.11.0 and numpy 1.6.2 with windows 7 os. When I tried to run the test case of rotating airfoil at command prompt: python "D:\Program Files\SU2\shape_optimization.py" -f rot_NACA0012.cfg Follwing error displayed: found: mesh_NACA0012_rot.su2 New Project: ./ Warning, removing old designs... now New Design: DESIGNS/DSN_001 ./DESIGNS/DSN_001 ./DESIGNS/DSN_001 NIT FC OBJFUN GNORM ./DESIGNS/DSN_001 Evaluate Objectives Drag... Traceback (most recent call last): File "D:\Program Files\SU2\shape_optimization.py", line 124, in <module> main() File "D:\Program Files\SU2\shape_optimization.py", line 69, in main options.step ) File "D:\Program Files\SU2\shape_optimization.py", line 107, in shape_optimization SU2.opt.SLSQP(project,x0,xb,its) File "D:\Program Files\SU2\SU2\opt\scipy_tools.py", line 102, in scipy_slsqp epsilon = 1.0e-06 ) File "D:\Python26\lib\site-packages\scipy\optimize\slsqp.py", line 196, in fmi n_slsqp constraints=cons, **opts) File "D:\Python26\lib\site-packages\scipy\optimize\slsqp.py", line 351, in _mi nimize_slsqp fx = func(x) File "D:\Python26\lib\site-packages\scipy\optimize\optimize.py", line 268, in function_wrapper return function(x, *args) File "D:\Program Files\SU2\SU2\opt\scipy_tools.py", line 120, in obj_f obj = project.obj_f(x) File "D:\Program Files\SU2\SU2\opt\project.py", line 203, in obj_f return self._eval(konfig, func,dvs) File "D:\Program Files\SU2\SU2\opt\project.py", line 172, in _eval vals = design._eval(func,*args) File "D:\Program Files\SU2\SU2\eval\design.py", line 132, in _eval vals = eval_func(*inputs) File "D:\Program Files\SU2\SU2\eval\design.py", line 230, in obj_f func = su2func(this_obj,config,state) File "D:\Program Files\SU2\SU2\eval\functions.py", line 75, in function aerodynamics( config, state ) File "D:\Program Files\SU2\SU2\eval\functions.py", line 200, in aerodynamics info = su2run.direct(config) File "D:\Program Files\SU2\SU2\run\direct.py", line 75, in direct SU2_CFD(konfig) File "D:\Program Files\SU2\SU2\run\interface.py", line 92, in CFD the_Command = build_command( the_Command , processes ) File "D:\Program Files\SU2\SU2\run\interface.py", line 255, in build_command raise RuntimeError , 'could not find an mpi interface' RuntimeError: could not find an mpi interface E:\su2\case\naca0012> /////////////////////////////////////////////////////////////////////////////// if I use following command python "D:\Program Files\SU2\shape_optimization.py" f rot_NACA0012.cfg Follwing error displayed: Traceback (most recent call last): File "D:\Program Files\SU2\shape_optimization.py", line 124, in <module> main() File "D:\Program Files\SU2\shape_optimization.py", line 69, in main options.step ) File "D:\Program Files\SU2\shape_optimization.py", line 85, in shape_optimization config = SU2.io.Config(filename) File "D:\Program Files\SU2\SU2\io\config.py", line 84, in __init__ super(Config,self).__init__(*args,**kwarg) File "D:\Program Files\SU2\SU2\util\ordered_bunch.py", line 83, in __init__ super(OrderedBunch,self).__init__(*args,**kwarg) File "D:\Program Files\SU2\SU2\util\ordered_dict.py", line 44, in __init__ self.__update(*args, **kwds) File "D:\Program Files\SU2\SU2\util\ordered_dict.py", line 170, in update for key, value in other: TypeError: 'NoneType' object is not iterable I have set PYTHONPATH enviroment variable including "D:\Program Files\SU2"; can you give me some help? Best wish |
February 15, 2014, 22:50 |
Yibin Dou
Rep Power: 16 |
hello
February 16, 2014, 16:36 |
Trent Lukaczyk
Rep Power: 15 |
Hi Yibin,
Shape optimization defaults to a 1-processor mpi call, which is why you are getting that error message. Please add the option -p 0 to your command call, to run this command in serial mode. Best, - rkchip |
February 18, 2014, 08:07 |
Yibin Dou
Rep Power: 16 |
hi rkchip
Thanks for your help. Following your suggestion and I reinstall the su2 in C:\SU2 path, then everything is ok! thank you best wish |
April 15, 2014, 03:27 |
Khiem Pham
Rep Power: 12 |
Dear sirs
I also have problem while trying to run shape_optimization.py (tutorial 7 in test case). I install SU2-3.0.000-64-bit-parallel-threaded.exe, python 2.7.6, scipy 0.13.0-py27 and numpy MKL 1.8 –py27 I set my SU2_HOME=C:\SU2;SU2_RUN=C:\SU2;C:\SU2\SU2;PYTHONPA TH=C:\SU2; I also add C:\SU2 in path environment. What is wrong? Thanks for your answers. su2.jpg su22.jpg Last edited by Bachduong; April 20, 2014 at 03:34. |
April 23, 2014, 14:32 |
Marco C.
Rep Power: 12 |
I have the same problem, but since I am a complete novice in python I haven't been able to understand the reason.
I'm trying to run the rotating NACA 0012 tutorial and I'm getting this error: TypeError: 'NoneType' object is not iterable Thanks in advance for your help! |
May 3, 2014, 00:41 |
add -p 0, still error
WangJianliang
Rep Power: 15 |
C:\work\su2\naca0012>shape_optimization.py f rot_NACA0012.cfg -p 0
Traceback (most recent call last): File "D:\SU2\shape_optimization.py", line 124, in <module> main() File "D:\SU2\shape_optimization.py", line 69, in main options.step ) File "D:\SU2\shape_optimization.py", line 85, in shape_optimization config = SU2.io.Config(filename) File "D:\SU2\SU2\io\config.py", line 84, in __init__ super(Config,self).__init__(*args,**kwarg) File "D:\SU2\SU2\util\ordered_bunch.py", line 83, in __init__ super(OrderedBunch,self).__init__(*args,**kwarg) File "D:\SU2\SU2\util\ordered_dict.py", line 44, in __init__ self.__update(*args, **kwds) File "D:\SU2\SU2\util\ordered_dict.py", line 170, in update for key, value in other: TypeError: 'NoneType' object is not iterable |
May 7, 2014, 03:08 |
#8 | |
Khiem Pham
Rep Power: 12 |
You need write C:\work\su2\naca0012>shape_optimization.py -f rot_NACA0012.cfg -p 0 rather than C:\work\su2\naca0012>shape_optimization.py f rot_NACA0012.cfg -p 0 |
May 7, 2014, 03:32 |
yes you are right
#9 |
Wang Jianliang
Thank you very much, the tutorial manual was error miss the "-" before the f
and if is on windows, earlier version python have the NodeType error, should to change the __ini__ file Thanks |
June 5, 2014, 14:56 |
#10 |
Trent Lukaczyk
Rep Power: 15 |
Thanks everyone, we fixed the tutorial
October 14, 2014, 18:41 |
#11 |
Rep Power: 13 |
I had the same problem with the inv_oneram6_adv.cfg (Optimized_euler/steady_oneram6). I noted that you said you fixed the tutorial and wanted to make sure that this one also got fixed.
Test case for rans optimization? | hejiandong | SU2 Shape Design | 6 | March 3, 2014 21:06 |
Multiple FFD box definition for shape optimization study | diwakaranant | SU2 | 1 | November 5, 2013 17:46 |
Error in optimization of the RAE2822 airfoil with the mesh in the test case | Tommy Chen | SU2 Shape Design | 26 | May 30, 2013 05:37 |
Problem with plasma test case: residuals are NAN | rafpepe | SU2 | 2 | January 20, 2013 09:37 |
SQP method for adjoint based aerodynamic shape optimization | cfdbooks | Main CFD Forum | 2 | May 26, 2009 10:40 |
