Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Stop after first iteration
Like Tree1Likes
  • 1 Post By talbring
Old   January 24, 2016, 15:02
Default Stop after first iteration
Massachusetts
kayla1994 is on a distinguished road
hello,
I'm running the shape optimization to minimize the drag of a NACA airfoil. I used the configuration present in the test cases and i substituted the native mesh with my own mesh, but i don't know why the process stops after the first iteration.
Any idea about the source of the problem?
Also i don't understand what is the scale factor of the objective function.
Thanks for help
kayla1994 is offline   Reply With Quote
Old   January 24, 2016, 16:03
Massachusetts
i read the the force_breakdown.dat in the DIRECT folder prduced by the first step of the optimization and i noticed all the values are zero (CL, CD etc.), so this is the problem that stops the optimization at the first step. I don't think is a mesh problem because i run the same mesh and run correctly in the direct simulation, so i think is the .cfg
Old   January 24, 2016, 16:16
Massachusetts
Maybe i found the problem
here a screen of my terminal
http://i.imgur.com/mcJPray.jpg
It seems i did a mistake in the "initial guess of indipendent variables". Honestly i have no idea whis is the right manner to set di parameters
Old   January 25, 2016, 16:36
Massachusetts
Now i think i set correctly all the parameters, and these are the errors
http://imgur.com/a/7kDpx
Old   January 26, 2016, 04:29
Tim Albring
talbring is on a distinguished road
Hi kayla1994,
you can have a look into DESIGNS/DSN_002/log_Direct.out to see why it fails.
kayla1994 likes this.
talbring is offline   Reply With Quote
Old   January 27, 2016, 12:35
Massachusetts
Originally Posted by talbring View Post
Hi kayla1994,
Thanks for your answer talbring
this is the message in log_DIRECT.out
!!! Error !!!
NACA5512_2_deform.cgns is not a CGNS file.
Now exiting...
NACA5512_2 is the name of my mesh in cgns format
You can find the part of the .cfg file that contains the INPUT/PUTPUT information at this link http://imgur.com/8G2Ls3p
Maybe it can help
Thanks for help
Old   February 19, 2016, 02:06
Francisco Palacios
fpalacios is on a distinguished road
Hi Kayla,
Please keep in mind that the shape design of SU2 only works with .su2 format (not cgns). This is because the grid deformation tool are not able to write the deformed grid in cgns format.
Best,
Francisco Palacios
fpalacios is offline   Reply With Quote
How To Stop The Iteration Process? sefde FLUENT 9 November 19, 2023 03:02
Hardware-Configuration for Fluent HPC-Pack (8x) JohHaas Hardware 9 March 3, 2015 13:25
When to stop the iteration? oldisbest FLUENT 7 May 20, 2013 00:50
Parallel runs slower with MTU=9000 than MTU=1500 Javier Larrondo FLUENT 0 October 28, 2007 22:30
How to stop iteration with TUI? sophie FLUENT 4 November 23, 2006 05:18
