Home > Forums > Software User Forums > SU2 > SU2 Shape Design
folded mesh in shape optimization of ONERA M6 shock bumps
Old   August 2, 2016, 05:57
Default folded mesh in shape optimization of ONERA M6 shock bumps
Ignatius Yudki Utama
uyuig0 is on a distinguished road
I'm currently trying to optimize ONERA M6 wing. I use 4.2.0 "Cardinal" version of SU2. My goal is to obtain optimum shock control bump (SCB) shape over a transonic wing (picture 0).
Picture 0
Because i'm lacking of wing-with-bumps data for validation, I define a FFD box at the upper part of normal wing which I predict will give me the bumps. I choose FFD_THICKNESS for design variable (details can be read in attached configuration file) and my FFD definition is:
FFD_DEFINITION= (WING_BOX, 0.131, 0, 0, 0.635, 0, 0, 1.046, 1.196, 0, 0.764, 1.196, 0, 0.131, 0, 0.05, 0.635, 0, 0.05, 1.046, 1.196, 0.05, 0.764, 1.196, 0.05)
I hope there will be a bump over the wing. However, when i use "shape_optimization.py", after the first function evaluation, parts of mesh in and around the FFD box are folded.
Here are my configuration file and optimization history:
turb_ONERAM6.txt
history_project.txt
My questions are:
1. Are there any incorrect set-up in my configuration file that makes the mesh folded?
2. Have I choose the correct design variable?
3. Are there some way to generate and optimize the wing shock bump in SU2?
Thank you in advance,
Yudki Utama
uyuig0 is offline   Reply With Quote
onera m6, optimization, shock control bumps, su2, transonic
[ICEM] Problem Projected Mesh Shape DeanM ANSYS Meshing & Geometry 2 December 18, 2014 02:55
FSI/MFX: folded mesh after changing Air to Water gogohusky CFX 4 April 24, 2012 09:26
Mesh elements shape on faces Mohsin FLUENT 3 August 17, 2011 02:37
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
