Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Airfoil shape design
Like Tree1Likes
  • 1 Post By pcg
Old   June 7, 2021, 07:53
Smile Airfoil shape design
Stefano Segneri
Stefano Segneri is on a distinguished road
Hello everyone.
I am using SU2 for the optimization of an airfoil (subsonic, turbulent case). The airfoil (BE 123-155) will be used as a GT-vehicle spoiler, thus in ground effect. The objective function is the CL and there are no constraints for DRAG end MOMENTUM.
The problem is that after some iterations the thikness reduces almost to zero in some parts. I have tried using OPT_CONSTRAINT=( AIRFOIL_THICKNESS > ### ) because that's what they do in in the tutorials but the problem is still happening.
Any advice??
Thanks to everyone
Stefano Segneri is offline   Reply With Quote
Old   June 7, 2021, 17:15
pcg
Pedro Gomes
pcg is on a distinguished road
Airfoil thickness is the maximum thickness, as in 12% for the NACA0012.
The most effective way is to limit the range of the variables so that it is not possible for the thickness to become to low.
Stefano Segneri likes this.
pcg is offline   Reply With Quote
Old   June 8, 2021, 02:40
Stefano Segneri
Originally Posted by pcg View Post
Thanks a lot!
airfoil optimization
airfoil optimization with multiple DV_MARKER (su2 6.0.0) bornax SU2 Shape Design 4 July 25, 2022 20:56
Continuous adjoint converge issue in transonic airfoil shape design zloty001 SU2 Shape Design 0 December 15, 2019 09:13
FFD 2D for inverse shape design using target CP ericclaro SU2 Shape Design 1 May 30, 2019 18:53
Diverging Tutorial: "Optimal Shape Design of a Rotating Airfoil" Clancy SU2 2 April 24, 2015 13:18
Bezier-Bernstein approximation for airfoil shape DoHander Main CFD Forum 10 April 23, 2014 06:21
