August 7, 2023, 16:16 |
SU2 NEMO with adjoint method
Hi everyone,
I am trying to do a 2D shape optimization case in hypersonic regime, using discrete adjoint. Before to try that I try to know and use successful the adjoint method in SU2 (no NEMO version so without Mutation). After I used SU2 NEMO with Mutation++, but without adjoint libraries, for hypersonic cases. Now I am trying to install SU2 with Mutation++ and adjoint libraries together. After to download the Su2 Code from Github, I run the following command line: ./meson.py build -Denable-cgns=false -Denable-mpp=true -Denable-tecio=true -Denable-autodiff=true -Denable-directdiff=true --prefix=/home/aleapo/SU2_NEMO2/SU2 After copy the 6 lines in my bashrc, I run the following command line: ./ninja -C build install But I obtain the errors that I show in the images Do you have any ideas on how I can solve the problem? I don't find any documentation about SU2 NEMO + adjoint method, is adjoint method implemented in SU2 NEMO? Thanks you in advance |
Harmonic balance method for calculating multi-stage turbines | HIT19B902072 | SU2 | 2 | April 24, 2022 01:31 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 05:18 |
Is SU2 able to handle adjoint for pressure distribution when doing inverse design? | Xiaosong | SU2 | 2 | December 4, 2016 00:25 |
Problems launching adjoint | max_ | SU2 | 2 | March 12, 2016 11:32 |
Boundary Conditions Of Discrete Adjoint Method For 2D NS Equations | Ashkaari | Main CFD Forum | 4 | January 27, 2016 20:05 |
