Home > Forums > Software User Forums > SU2
Incompressible viscous flow around NACA0012
Like Tree1Likes
  • 1 Post By robyTKD
Old   January 10, 2013, 18:21
Default Incompressible viscous flow around NACA0012
Roberto Pieri
robyTKD is on a distinguished road
Hello to everyone,
I am a Politecnico di Milano student and I am using SU2 in my Master thesis involving racecar aerodynamics.
My first goal is to analyze the viscous flow around NACA0012 profile in incompressible conditions; in particular I'm trying to reproduce these results: http://turbmodels.larc.nasa.gov/naca0012_val_sa.html.
The mesh used in my simulations is not the same as the one used in the report. It's a C-mesh of quadrangle elements around a NACA0012 of unitary chord length; boundaries of the domain are 30 chord unities far from the leading and trailing edge.
Unfortunately I am not able to make the solution converge; the only settings that gave me results are reported in the configuration file attached below, but they don't match the reference.
I've not been able to attach the mesh file because it exceeds maximum dimensions.
Could you please provide me help and feedback about my situation?
Thank you very much in advance.
Roberto
samiam1000 likes this.
robyTKD is offline   Reply With Quote
Old   January 10, 2013, 18:31
Roberto Pieri
And here there is the configuration file.
Old   January 17, 2013, 23:46
Francisco Palacios
fpalacios is on a distinguished road
Originally Posted by robyTKD View Post
Hello to everyone,
Roberto
Hi Roberto,
Thanks for your interest in SU2. I think that this simulation should work with the appropriate set of parameters. Please find attached a suggested config file, unfortunately I don't have the right grid for Reynolds 6M. Could you please post the grid that you are using?
Best,
Francisco
default.cfg.zip
fpalacios is offline   Reply With Quote
Old   January 18, 2013, 10:23
Roberto Pieri
Hi Francisco,
thank you for the reply and for the configuration file.
Unfortunately it didn't make the case converge, so I changed some settings and now it seems to converge(modified config file is attached below).
At 0 angle of attack the solution is right.
Moving to my case (10 degrees angle of attack), results of the simulation (Cl=0.99, Cd=0.022) differ from the reference (Cl=1.09, Cd=0.012); this is strange because the solution seems smooth and also the Cp is regular (see figures attached below).
How can I solve this problem? Is there an error in the code or my settings are wrong?
I have a further question: is it possible to run the ADJOINT with the incompressible formulation?
This is my mesh: http://www.4shared.com/zip/8Zgpycw1/...12_40ksu2.html.
Thank you very much,
Roberto
Old   February 6, 2013, 02:03
Cean
shirazbj is on a distinguished road
I am interested in imcompressable case too.
I tried you cfg and mesh.
Here is a result after 2000 steps. Your grid may not suit.
shirazbj is offline   Reply With Quote
Old   April 21, 2013, 13:10
Default Incompressible AoA??
dtucker's Avatar
David Tucker
dtucker is on a distinguished road
Is there a way to specify AoA with an incompressible case without having to do the trig??
...call me lazy, but I want to do a large range of angles and it would be much faster if I could just specify a velocity and angle.
Is there a way to do this, or is there some obstacle I'm not considering?
Thanks,
Dave
dtucker is offline   Reply With Quote
Old   April 21, 2013, 13:38
taxalian is on a distinguished road
Send a message via Skype™ to taxalian
Hi Roberto,
To better predict the cl values vs Experiment at higher angles of attack. Well i think, first of all you should make sure that your yplus value should be less than one.
Regards.
taxalian is offline   Reply With Quote
incompressible, naca0012, rans
An FASMultigrid solver for steady incompressible viscous flow luca_g OpenFOAM Running, Solving & CFD 3 September 21, 2009 02:30
Non viscous flow gat CFX 0 April 10, 2009 05:31
3D Incompressible turbulent flow validation case Yu Main CFD Forum 2 April 4, 2008 03:13
Reynold's number and incompressible flow Neil Main CFD Forum 3 October 24, 2006 08:11
AMR with Incompressible Flow Shahriar Main CFD Forum 7 March 7, 2003 08:53
