May 30, 2013, 13:12 |
Convergence accelaration
Amit
Rep Power: 13 |
Hi SU2 developers,
I have started exploring SU2. Onera-M6 wing simulation (RANS), took around 15000 iterations for convergence. I urge developers to give a try to (LU-SGS+GMRES) matrix free implicit method (which is supposed to give much faster convergence). Also some of the commercial software uses good initialization. For example Fluent uses so called FMG (Full Multigrid) initialization to obtain good initial solution (Euler). With this initial solution, one can quickly arrive at converged results. My experiences with some of the commercial software -->> converged results for forces and moments are obtained within 300 to 1000 iterations for most of the cases. I am sure SU2 will come to this level very soon Thanks and Regards Amit (Harry) |
June 13, 2013, 17:02 |
Rep Power: 14 |
Hi Amit,
Thank you for your suggestions! We are continually working on improving the code's capabilities, and initialization and inversion methods are certainly items we hope to improve in coming releases. Kind regards, Aniket |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Time step dependence of convergence behavior of steady state simulations in CFX | Chander | Main CFD Forum | 5 | December 23, 2013 05:31 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
Defect correction and convergence | ganesh | Main CFD Forum | 4 | June 30, 2006 14:20 |
