Home > Forums > Software User Forums > SU2
Can not get the right result at AoA=10 for RANS simulation of the NACA0012
Old   August 18, 2013, 05:39
Default Can not get the right result at AoA=10 for RANS simulation of the NACA0012
Jianming Liu
liujmljm is on a distinguished road
Dear, I try to simulate NACA0012 airfoil at AoA =10, Mach=0.15, Re=6e6. Based the grid provided at the folder of Testcase/rans/naca0012. The CL calculated by SU2 is about 0.4. But the right result should be about 1. Does anyone test the case? Thank you very much.
The configure file is attached.
liujmljm is offline   Reply With Quote
Old   August 18, 2013, 08:51
Jianming Liu
The solver can not converge. Do we need use lower mach preconditioning.
Thank you
Old   August 19, 2013, 01:25
Francisco Palacios
fpalacios is on a distinguished road
I think there must be something wrong in the config file that you are using. Could you please try with the attached config file, the current developer's version of SU2 (you can fork the repository in https://github.com/su2code/SU2), and the grid TestCases/rans/naca0012/mesh_NACA0012_turb_897x257.su2.
The results (AoA =10, Mach=0.15, Re=6e6) are in a very good agreement with the experimental data (CL = 1.0989, CD = 0.0128). Note that the config file only works with the latest version of SU2.
Best,
Francisco
fpalacios is offline   Reply With Quote
Difference of result betn Fluent & CFX simulation for S2S radiation njundale Fluent UDF and Scheme Programming 0 November 6, 2012 00:35
I want NACA0012 simulation datas Santana Main CFD Forum 2 December 28, 2004 11:58
how to make sure the simulation result is correct? sham81 CFX 3 March 22, 2004 16:41
TASCflow simulation result problem? Mason CFX 0 February 22, 2004 07:54
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 10:06
