Home > Forums > Software User Forums > SU2
Need output format explanation
Old   December 5, 2013, 18:07
Default Need output format explanation
Ron Burnett
rnburne is on a distinguished road
The problem at hand involves simple isentropic expansion in a duct. The calculated values for p, T and rho (nondimensionalized by inlet stagnation values) at a particular location correspond exactly with a Mach number of .82, just as expected. However, the calculated values of M and V are given as .48 and .54 . How are these numbers to be interpreted?
rnburne is offline   Reply With Quote
Old   January 11, 2014, 22:29
Francisco Palacios
fpalacios is on a distinguished road
The non-dmensionalization is described in
https://adl.stanford.edu/papers/AIAA-2013-0287.pdf
and implemented in
void CConfig::SetNondimensionalization(unsigned short val_nDim, unsigned short val_iZone) in config_structure.cpp
Maybe the first step is to take a look at the document and the code.
Best Regards,
Francisco
fpalacios is offline   Reply With Quote
[swak4Foam] outputTime in Swak function immortality OpenFOAM Community Contributions 20 October 6, 2022 12:08
How to change Iterations Output format woodwick OpenFOAM 4 February 12, 2014 09:22
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 06:16
Fundamental output format control of field values and time dbxmcf OpenFOAM 1 January 12, 2011 10:50
[Other] Output Format of MetaMesh t42 OpenFOAM Meshing & Mesh Conversion 0 August 3, 2007 04:28
