Home > Forums > Software User Forums > SU2
Errors when compiling CGNS 3.1.3
Like Tree1Likes
  • 1 Post By Combas
Old   January 16, 2014, 23:14
Default Errors when compiling CGNS 3.1.3
Tommy Chen
Tommy Chen is on a distinguished road
I want to complie the CGNS library for compiling the new SU2 3.0
However when I use cmake command to complie it , I got the error message
"song@TommyThinkTwice:~/Desktop/temp/SU2/Eagle/cgnslib_3.1.3/build$ cmake ../src
CMake Warning at CMakeLists.txt:37 (if):
given arguments:
"GREATER" "4"
Unknown arguments specified
CMake Error at CMakeLists.txt:158 (set_target_properties):
set_target_properties called with incorrect number of arguments.
CMake Error at CMakeLists.txt:159 (set_target_properties):
CMake Error at CMakeLists.txt:162 (set_target_properties):
CMake Error at CMakeLists.txt:163 (set_target_properties):
-- Configuring incomplete, errors occurred!
Has anybody encountered similar problem ?
Tommy Chen is offline   Reply With Quote
Old   January 16, 2014, 23:15
Tommy Chen
Besides , my OS is Ubuntu 12.04
and my cmake version is 2.8.7
Old   January 18, 2014, 16:32
Combas is on a distinguished road
I tried with CGNS version 3.1.4-2 and I have the same problem, with the same configuration (Ubuntu 12.04 and cmake version 2.8.7)
If someone has a solution, I am also interested!
Combas is offline   Reply With Quote
Old   January 18, 2014, 16:40
Tommy Chen
Hey Combas , I have already solved that
you have to use ccmake to generate configuration file for cmake
then use cmake to gnerate the makefile
then make
Old   January 18, 2014, 17:09
Thank you for your answer, but I tried ccmake and I have some problems.
Do you remember which options you chose?
I put the message of ccmake in attachement.
Laurent
Old   January 18, 2014, 17:29
Tommy Chen
Laurent
Try not to build CGNS tools and shared libs.
Old   January 19, 2014, 02:25
Unfortunately, I have still the same problem...
Old   January 19, 2014, 08:41
Tommy Chen
Are you using the default settings ?
Old   January 19, 2014, 14:41
I have resolved my problem: I think it was because I launched "ccmake /home/laurent/SU2_V3/cgnslib_3.1.4/src" instead of "ccmake /home/laurent/SU2_V3/cgnslib_3.1.4"
(I had added the "src" directory because the source code is inside, but in fact it was probably an error)
With the default settings, now it works.
Thank you for you help Tommy !
Laurent
DLuo likes this.
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
