December 27, 2013, 01:56 |
Meaning of non-physical points ...
Rep Power: 16 |
Hi All,
I had few queries regarding SU2 terminology. 1. Several times I encounter this msg: The solution contains n non-physical points. What does this refer to ? 2. How are the residuals defined? Lets say the value at some iteration for variable 1 is -3.4567. What does it indicate? Does it mean log_10 (Var1_i iter/ Var1_ i-1 iter)? 3. Has anyone tried using 2 level Multigrid? How to decide optimal child/parent ratio for a given grid? Would appreciate your response. Thanks, Deepanshu. |
January 11, 2014, 22:05 |
Francisco Palacios
Rep Power: 15 |
Non-physical points means that after the solution update the density is negative.
Su2 computed the L2 norm of the residual and plots the Log10 of the value. In other words a value of -12 means that the residual is 10^-12. To set the optimal parameters of the MG is an art. when you have convergence issues do not forget to reduce: % Damping factor for the residual restriction MG_DAMP_RESTRICTION= ____ % % Damping factor for the correction prolongation MG_DAMP_PROLONGATION= ____ Best Regards, Francisco |
January 13, 2014, 00:20 |
Rep Power: 16 |
Dear Francisco,
Thank you for your inputs. Deepanshu. |
January 14, 2014, 17:51 |
Sean (J.X.) Shi
Rep Power: 13 |
Set Multigrid=0, the non-physical points can be removed.
It works sometimes for me. |
January 29, 2014, 01:04 |
Rep Power: 16 |
Thanks Sean for your inputs.
[snappyHexMesh] .STL: non-closed manifold surface | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 32 | November 25, 2016 03:15 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
[DesignModeler] DM's JScript: FPoint()'s GetPoint(i) function picks points backwards? | ANT | ANSYS Meshing & Geometry | 2 | July 23, 2012 15:25 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
