Home > Forums > Software User Forums > SU2
Incompressible simulation
Old   April 15, 2014, 08:54
Default Incompressible simulation
Brugiere Olivier
brugiere_olivier is on a distinguished road
hi all,
I'm new user of SU2. I would like to make tests of the adjoint solver on a rear-view mirror to reduce the drag coefficient.
In SU2 v2.0, I can make a simulation without the adjoint part. I've upgraded my version of SU2 and I can't reproduce this case now. I don't find how to have wall without temperature like with MARKER_NS. To the car and the rear-view mirror, I've four boundary conditions (car, arm, mirror and mirror_plate).
If some body can give me some advices, I give my configuration file.
% Stanford University unstructured (SU2) configuration file                    %
% Case description: Turbulent flow over flat plate with zero pressure gradient %
% Author: Thomas D. Economon                                                   %
% Institution: Stanford University                                             %
% Date: 2011.11.10                                                             %
% File Version 1.0.12 January 5th, 2012                                        %
% ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------%
% Physical governing equations (EULER, NAVIER_STOKES,
%                               TNE2_EULER, TNE2_NAVIER_STOKES,
%                               WAVE_EQUATION, HEAT_EQUATION, LINEAR_ELASTICITY,
%                               POISSON_EQUATION)
PHYSICAL_PROBLEM= NAVIER_STOKES
% Specify turbulence model (NONE, SA, SST)
KIND_TURB_MODEL= SA
% Mathematical problem (DIRECT, ADJOINT, LINEARIZED)
MATH_PROBLEM= DIRECT
% Restart solution (NO, YES)
RESTART_SOL= NO
% Regime type (COMPRESSIBLE, INCOMPRESSIBLE, FREESURFACE)
REGIME_TYPE= INCOMPRESSIBLE
% Gravity force, only incompressible (NO, YES)
GRAVITY_FORCE= NO
% Axisymmetric simulation, only compressible (NO, YES)
AXISYMMETRIC= NO
% Perform a low fidelity simulation (NO, YES)
LOW_FIDELITY_SIMULATION= NO
% -------------------- INCOMPRESSIBLE FREE-STREAM DEFINITION ------------------%
% Free-stream density (1.2886 Kg/m^3 (air), 998.2 Kg/m^3 (water))
FREESTREAM_DENSITY= 1.2886
% Free-stream velocity (m/s)
FREESTREAM_VELOCITY= ( 33.3333, 0.00, 0.00 ) % 120 km/h
% Free-stream viscosity (1.853E-5 Ns/m^2 (air), 0.798E-3 Ns/m^2 (water))
FREESTREAM_VISCOSITY= 1.853E-5
% -------------- COMPRESSIBLE AND INCOMPRESSIBLE FLUID CONSTANTS --------------%
% Ratio of specific heats (1.4 (air), only for compressible flows)
GAMMA_VALUE= 1.4
% Specific gas constant (287.87 J/kg*K (air), only for compressible flows)
GAS_CONSTANT= 287.87
% Laminar Prandtl number (0.72 (air), only for compressible flows)
PRANDTL_LAM= 0.72
% Turbulent Prandtl number (0.9 (air), only for compressible flows)
PRANDTL_TURB= 0.9
% Value of the Bulk Modulus (1.42E5 N/m^2 (air), 2.2E9 N/m^2 (water),
% only for incompressible flows)
BULK_MODULUS= 1.42E5
% Artifical compressibility factor (1.0 by default,
ARTCOMP_FACTOR= 1.0
% ---------------------- REFERENCE VALUE DEFINITION ---------------------------%
% Reference origin for moment computation
REF_ORIGIN_MOMENT_X = 0.547
REF_ORIGIN_MOMENT_Y = -0.786
REF_ORIGIN_MOMENT_Z = 0.811
% Reference length for pitching, rolling, and yawing non-dimensional moment
REF_LENGTH_MOMENT= 0.205
% Reference area for force coefficients (0 implies automatic calculation)
REF_AREA= 0
% ------------------------- UNSTEADY SIMULATION -------------------------------%
% Unsteady simulation (NO, TIME_STEPPING, DUAL_TIME_STEPPING-1ST_ORDER,
%                      DUAL_TIME_STEPPING-2ND_ORDER)
UNSTEADY_SIMULATION= NO
% Time Step for dual time stepping simulations (s)
UNST_TIMESTEP= 0.0
% Total Physical Time for dual time stepping simulations (s)
UNST_TIME= 50.0
% Unsteady Courant-Friedrichs-Lewy number of the finest grid
UNST_CFL_NUMBER= 0.0
% Number of internal iterations (dual time method)
UNST_INT_ITER= 200
% Integer number of periodic time instances for Time Spectral
TIME_INSTANCES= 1
% -------------------- BOUNDARY CONDITION DEFINITION --------------------------%
% Navier-Stokes wall boundary marker(s) (NONE = no marker)
MARKER_ISOTHERMAL= ( car, mirror, mirror_plate, bras )
% Farfield boundary marker(s) (NONE = no marker)
MARKER_FAR= ( inlet, bottom, top_4, side+, outlet_2 )
% Symmetry boundary marker(s) (NONE = no marker)
MARKER_SYM= ( side- )
% ------------------------ SURFACES IDENTIFICATION ----------------------------%
% Marker(s) of the surface to be plotted or designed
MARKER_PLOTTING= ( mirror, mirror_plate, bras )
% Marker(s) of the surface where the functional (Cd, Cl, etc.) will be evaluated
MARKER_MONITORING= ( mirror, mirror_plate, bras )
% ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------%
% Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES)
NUM_METHOD_GRAD= WEIGHTED_LEAST_SQUARES
% Courant-Friedrichs-Lewy condition of the finest grid
CFL_NUMBER= 5.0
% CFL ramp (factor, number of iterations, CFL limit)
CFL_RAMP= ( 1.1, 100, 20.0 )
% Runge-Kutta alpha coefficients
RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 )
% Number of total iterations
EXT_ITER= 30
% -------------------------- MULTIGRID PARAMETERS -----------------------------%
% Multi-Grid Levels (0 = no multi-grid)
MGLEVEL= 2
% Multi-Grid Cycle (0 = V cycle, 1 = W Cycle)
MGCYCLE= 0
% CFL reduction factor on the coarse levels
MG_CFL_REDUCTION= 0.75
% Maximum number of children in the agglomeration stage
MAX_CHILDREN= 250
% Maximum length of an agglomerated element (relative to the domain)
MAX_DIMENSION= 0.1
% Multigrid pre-smoothing level
MG_PRE_SMOOTH= ( 1, 2, 3, 3 )
% Multigrid post-smoothing level
MG_POST_SMOOTH= ( 0, 0, 0, 0 )
% Jacobi implicit smoothing of the correction
MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0 )
% Damping factor for the residual restriction
MG_DAMP_RESTRICTION= 0.5
% Damping factor for the correction prolongation
MG_DAMP_PROLONGATION= 0.5
% -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------%
% Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC,
% TURKEL_PREC, MSW)
CONV_NUM_METHOD_FLOW= ROE
% Spatial numerical order integration (1ST_ORDER, 2ND_ORDER, 2ND_ORDER_LIMITER)
SPATIAL_ORDER_FLOW= 2ND_ORDER
% Slope limiter (VENKATAKRISHNAN, MINMOD)
SLOPE_LIMITER_FLOW= VENKATAKRISHNAN
% Coefficient for the limiter
LIMITER_COEFF= 0.3
% 1st, 2nd and 4th order artificial dissipation coefficients
AD_COEFF_FLOW= ( 0.15, 0.5, 0.02 )
% Viscous numerical method (AVG_GRAD, AVG_GRAD_CORRECTED, GALERKIN)
VISC_NUM_METHOD_FLOW= AVG_GRAD_CORRECTED
% Source term numerical method (PIECEWISE_CONSTANT)
SOUR_NUM_METHOD_FLOW= PIECEWISE_CONSTANT
% Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT)
TIME_DISCRE_FLOW= EULER_IMPLICIT
% -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------%
% Convective numerical method (SCALAR_UPWIND)
CONV_NUM_METHOD_TURB= SCALAR_UPWIND
SPATIAL_ORDER_TURB= 2ND_ORDER
SLOPE_LIMITER_TURB= VENKATAKRISHNAN
% Viscous numerical method (AVG_GRAD, AVG_GRAD_CORRECTED)
VISC_NUM_METHOD_TURB= AVG_GRAD_CORRECTED
SOUR_NUM_METHOD_TURB= PIECEWISE_CONSTANT
% Time discretization (EULER_IMPLICIT)
TIME_DISCRE_TURB= EULER_IMPLICIT
% Reduction factor of the CFL coefficient in the turbulence problem
CFL_REDUCTION_TURB= 1.0
% --------------------------- PARTITIONING STRATEGY ---------------------------%
% Write a paraview file for each partition (NO, YES)
VISUALIZE_PART= NO
% --------------------------- CONVERGENCE PARAMETERS --------------------------%
% Convergence criteria (CAUCHY, RESIDUAL)
CONV_CRITERIA= RESIDUAL
% Residual reduction (order of magnitude with respect to the initial value)
RESIDUAL_REDUCTION= 8
% Min value of the residual (log10 of the residual)
RESIDUAL_MINVAL= -10
% Start convergence criteria at iteration number
STARTCONV_ITER= 10
% Number of elements to apply the criteria
CAUCHY_ELEMS= 100
% Epsilon to control the series convergence
CAUCHY_EPS= 1E-6
% Function to apply the criteria (LIFT, DRAG, NEARFIELD_PRESS, SENS_GEOMETRY,
% SENS_MACH, DELTA_LIFT, DELTA_DRAG)
CAUCHY_FUNC_FLOW= DRAG
% Epsilon for full multigrid method evaluation
FULLMG_CAUCHY_EPS= 1E-4
% ------------------------- INPUT/OUTPUT INFORMATION --------------------------%
% Mesh input file
MESH_FILENAME= Retro.su2
% Mesh input file format (SU2, CGNS, NETCDF_ASCII)
MESH_FORMAT= SU2
% Convert a CGNS mesh to SU2 format (YES, NO)
CGNS_TO_SU2= NO
% Mesh output file
MESH_OUT_FILENAME= mesh_out.su2
% Restart flow input file
SOLUTION_FLOW_FILENAME= solution_flow.dat
% Restart adjoint input file
SOLUTION_ADJ_FILENAME= solution_adj.dat
% Output file format (PARAVIEW, TECPLOT, SLT)
OUTPUT_FORMAT= PARAVIEW
% Output file convergence history (w/o extension)
CONV_FILENAME= history
% Output file restart flow
RESTART_FLOW_FILENAME= restart_flow.dat
% Output file restart adjoint
RESTART_ADJ_FILENAME= restart_adj.dat
% Output file linear flow
RESTART_LIN_FILENAME= restart_lin.dat
% Output file flow (w/o extension) variables
VOLUME_FLOW_FILENAME= flow
% Output file adjoint (w/o extension) variables
VOLUME_ADJ_FILENAME= adjoint
% Output file linearized (w/o extension) variables
VOLUME_LIN_FILENAME= linearized
% Output objective function gradient (using continuous adjoint)
GRAD_OBJFUNC_FILENAME= of_grad.dat
% Output file surface flow coefficient (w/o extension)
SURFACE_FLOW_FILENAME= surface_flow
% Output file surface adjoint coefficient (w/o extension)
SURFACE_ADJ_FILENAME= surface_adjoint
% Output file surface linear coefficient (w/o extension)
SURFACE_LIN_FILENAME= surface_linear
% Writing solution file frequency
WRT_SOL_FREQ= 10
% Writing convergence history frequency
WRT_CON_FREQ= 1
% Write unsteady data adding headers and prefixes (NO, YES)
WRT_UNSTEADY= NO
Thanks for your answers
Regards
Olivier
brugiere_olivier is offline   Reply With Quote
Old   April 15, 2014, 09:59
Thumbs up
taxalian is on a distinguished road
Send a message via Skype™ to taxalian
Simply replace the Navier-Stokes makers in your config file with the following parameter:
MARKER_HEATFLUX= ( car, 0.0 )
and so on for the rest of boundary markers.
NOTE: Normally you should find all the updates within the config_template.cfg file supplied with each release of SU2.
Hope this helps
Taxalian.
Originally Posted by brugiere_olivier View Post
hi all,
%                               POISSON_EQUATION)
KIND_TURB_MODEL= SA
RESTART_SOL= NO
GRAVITY_FORCE= NO
AXISYMMETRIC= NO
GAMMA_VALUE= 1.4
PRANDTL_LAM= 0.72
PRANDTL_TURB= 0.9
ARTCOMP_FACTOR= 1.0
REF_AREA= 0
UNST_TIMESTEP= 0.0
UNST_TIME= 50.0
UNST_INT_ITER= 200
TIME_INSTANCES= 1
CFL_NUMBER= 5.0
EXT_ITER= 30
MGLEVEL= 2
MGCYCLE= 0
MAX_CHILDREN= 250
MAX_DIMENSION= 0.1
% TURKEL_PREC, MSW)
LIMITER_COEFF= 0.3
VISUALIZE_PART= NO
STARTCONV_ITER= 10
CAUCHY_ELEMS= 100
CAUCHY_EPS= 1E-6
% Mesh input file
MESH_FORMAT= SU2
CGNS_TO_SU2= NO
% Mesh output file
WRT_SOL_FREQ= 10
WRT_CON_FREQ= 1
WRT_UNSTEADY= NO
Regards
Olivier
taxalian is offline   Reply With Quote
Old   April 15, 2014, 10:12
Brugiere Olivier
Thanks for your answer. I've find my mistake
Regards
Olivier
Requiring some help regarding tornado simulation amarjogot Main CFD Forum 0 June 20, 2013 12:26
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
Need help on simulation of incompressible flow in an orifice meter mep10jl FLUENT 0 November 18, 2010 19:25
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 08:18
FSI TWO-WAY SIMULATION Smagmon CFX 1 March 6, 2009 13:24
