Home > Forums > Software User Forums > SU2
correct .cfg files for 3.1.0
Old   May 23, 2014, 14:28
Default correct .cfg files for 3.1.0
Hedley
hedley is on a distinguished road
Where would I find the .cfg files that work with 3.1.0 . I have downloaded the latest mesh files but running the sample files does not seem to work . Could someone post .cfd files that work with the tutorials for 3.1.0 which would be a good sanity check .
hedley is offline   Reply With Quote
Old   May 25, 2014, 08:07
nilesh
nilesh is on a distinguished road
There is a file called "config_template" in the root of SU2 directory which works well for me.
nilesh is offline   Reply With Quote
Old   May 25, 2014, 08:30
Default .cfg template
Hedley
Yes thanks I have looked at that but what I was after was the .cfg file that actually works and produces the expected results for each of the tutorials .
I suspect that things have changed rapidly , this can be seen by the various mesh files for the RANS tutorials in 3.1.0 TestCases BUT the corresponding .cfg file is perhaps 2 years old so is out of sync and causes failures .
If I could work through all of the tutorials with supplied and tested .cfg files on supplied and tested mesh files .SU then I would have some confidence in the toolchain from start to visualization of the results .
Old   May 25, 2014, 08:53
Default example error
Hedley
after 4 hours on my home PC using the supplied ONERAM6 and the supplied mesh I get the attached error .
Old   May 25, 2014, 10:21
nilesh
Yes, I agree that the config files have not been updated.
As soon as SU2 begins, keep an eye for statements like
"Warning! Unrecognized Option: <name of option>". You could look up for the changed names of options by comparing the description comments in the template file.
ONERAM6 config file is runs without any changes on my machine.
Old   May 26, 2014, 03:59
cean wang
ceanwang is on a distinguished road
under which folder is this oneram6 config file?
I can't run su2 for any testcase for a while.
ceanwang is offline   Reply With Quote
Old   May 26, 2014, 09:42
Default .cfg files
Hedley
None of the .cfg files seem to be in any folder for the 3.1.0 - I try using older .cfg files and this is where the confusion starts . That is why I have been requesting a set of .cfg files that work with the tutorials and the latest mesh files . This will enable new users such as myself to run the tutorials and start off by knowing that the tool-chain is robust and produces repeatable results .
After this we could run our own sections and meshes
Old   May 28, 2014, 00:35
nilesh
New config files are present in he "TestCases" which is present in the root of the source code directory.
Old   May 28, 2014, 07:59
cean wang
cool. TestCases\rans\oneram6.
I copied a wrong mesh last time.
Old   June 5, 2014, 14:48
Brendan Tracey
btracey is on a distinguished road
You are right that many of the config files are out of date. This is something we are unhappy with, and we will be working in the near future to have correct config files available.
btracey is offline   Reply With Quote
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
Monitor Files Missing Forrest FLUENT 3 March 24, 2009 16:11
Problems with result files Kasper CFX 5 December 14, 2006 02:41
Automatic moving of files Jörn Beilke Siemens 0 November 7, 2004 14:11
