Home > Forums > Software User Forums > SU2
Reference parameter specification in .cfg file for compressible viscous flows
Old   June 19, 2014, 02:19
Default Reference parameter specification in .cfg file for compressible viscous flows
Suman Vajjala
SumanVajjala is on a distinguished road
I am using SU2 to simulate viscous compressible flows. In creating a .cfg file I want to know how REF_PRESSURE, REF_TEMPERATURE and REF_DENSITY are calculated. Are they freestream values? Also, in Euler simulations FREESTREAM_PRESSURE, FREESTREAM_TEMPERATURE is specified. What is the rationale behind this? Is FREESTREAM_TEMPERATURE different from REF_TEMPERATURE?
As a separate discussion what is the equation for the CFL ramping. In the included testcases (TestCases/rans/oneram6/turb_ONERAM6.cfg) CFL number is greater than CFL limit? Is this correct?
Many Thanks
Suman
SumanVajjala is offline   Reply With Quote
Old   June 25, 2014, 23:58
Francisco Palacios
fpalacios is on a distinguished road
Dear Suman,
The nondimensionalization is described in
http://su2.stanford.edu/documents/SU2_AIAA_ASM2013.pdf
If you are interested, the implementation is in
void CConfig::SetNondimensionalization(unsigned short val_nDim, unsigned short val_iZone)
The CFL ramp is described in
void CConfig::UpdateCFL(unsigned long val_iter)
Thanks for using Su2,
Cheers,
Francisco
fpalacios is offline   Reply With Quote
cfl specification, reference parameters
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 15:14
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
