Home > Forums > Software User Forums > SU2
Divide rectangles into triangles
Old   June 16, 2014, 06:32
Default Divide rectangles into triangles
nilesh
nilesh is on a distinguished road
I created a mesh containing rectangles and enabled this option in the config file:
% Divide rectangles into triangles (NO, YES)
DIVIDE_ELEMENTS= YES
However, the results are exactly the same. I opened some flow result files and found that the grid still contained rectangles. Is there anything else that needs to be changed?
Thanks.
nilesh is offline   Reply With Quote
Old   June 24, 2014, 17:02
Thomas D. Economon
economon is on a distinguished road
The element division capability is currently supported only for the mesh deformation code, SU2_DEF.
If you would like to experiment with the element division for the CFD solver, you can comment out the following around line near ~1200 of config_structure.cpp:
if (Kind_SU2 != SU2_DEF) Divide_Element = false;
However, please note that there are no guarantees on performance with this modification, but you might give it a try.
Cheers,
Tom
economon is offline   Reply With Quote
Old   June 25, 2014, 02:49
nilesh
Originally Posted by economon View Post
Cheers,
Tom
Thanks a lot. I will give it a try and compare the results.
Divide Prismatic Boundary Layer Mesh causes overlapping faces SilentRunner42 enGrid 4 May 4, 2015 03:37
How to divide all entries in 0/p by rho lentschi OpenFOAM 1 March 16, 2011 13:42
[ICEM] Importing a set of triangles into ICEM CFD rambabu ANSYS Meshing & Geometry 5 November 12, 2009 17:13
how to divide domain? manish Phoenics 0 May 10, 2006 02:25
higher gauss Quadrature rule for triangles R.A.Khurram Main CFD Forum 1 September 27, 2001 13:39
