September 20, 2014, 02:00 |
SU2 in parallel
Suman Chakraborty
Rep Power: 11 |
Can someone please help me with the command to run SU2 in parallel.
I have configured it with the metis libraries and MPI flies. I know that the parallel python script is to be run. Please tell me the command to use to run the code in parallel. One more thing is while running the code in parallel I should be in which folder - the Testcase with the config file or SU2_PY. Will be waiting for a reply. Thanks. |
September 20, 2014, 06:33 |
#2 | |
Khiem Pham
Rep Power: 12 |
You should type, for example
Hope this help. |
September 20, 2014, 07:49 |
Suman Chakraborty
Rep Power: 11 |
Thanx for the reply. This I should try while in the Test case folder or in the SU2_PY folder.
September 20, 2014, 08:37 |
Suman Chakraborty
Rep Power: 11 |
It worked. Thanx
SU2 Parallel Computation problem | Gramanzini | SU2 | 5 | September 29, 2018 12:32 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
parallel computation with SU2 V3.2 | 454514566@qq.com | SU2 | 1 | June 24, 2014 20:46 |
SU2 parallel installation error | JAlbert | SU2 Installation | 2 | November 19, 2013 02:43 |
Parallel SU2 | samiam1000 | SU2 | 5 | February 16, 2013 00:41 |
