Home > Forums > Software User Forums > SU2
How solution is initialized?
Old   November 25, 2014, 17:42
Default How solution is initialized?
Chintan Patel
chintan is on a distinguished road
Does SU2 initializes velocity to zero or it incorporates free stream conditions to initialize solution?
If not zero, is there a way to change that?
chintan is offline   Reply With Quote
Old   November 26, 2014, 03:50
Sachchit Vekaria
Sachchit is on a distinguished road
It will use free stream(farfield) conditions to initialize the solution. May I know why you would like to change it zero with non-zero freestream condition?
Sachchit is offline   Reply With Quote
Old   November 26, 2014, 12:23
Chintan Patel
Originally Posted by Sachchit View Post
Hi Sachchit,
Thanks for reply.
I have two inlets and both have velocities in orthogonal direction Having initialization orthogonal to inlet velocity in one duct either slows down convergence or diverges. FMRES blew up and BICGSTAB takes roughly more than thrice the time per iteration compared to FMRES). This isn't desired as I have mesh with more than 11M cells.
Starting with zero velocity everywhere is best bet for my case. It would be great if someone could point me how to modify code. Thanks.
Old   November 26, 2014, 13:01
Sachchit Vekaria
Hi Chintan,
What you can do is set the farfield mach number to be 0. And then define both the inlet as velocity inlet and assign other patches to be pressure outlet except walls.
One other way which might be helpful is to develop the solution with only one inlet on and then after reaching steady state restart the solution with both the inlets on.
Old   November 26, 2014, 13:09
Chintan Patel
Hi Chintan,
That's very helpful. Thanks a lot.
initialization
Why 3D solid-pore geometry showing diverged solution? Sargam05 OpenFOAM 0 December 3, 2012 15:45
Analytic solution for 2D steady Euler equations jojo81 Main CFD Forum 0 October 15, 2012 12:05
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
solution singularity litonx OpenFOAM Running, Solving & CFD 1 February 21, 2007 01:32
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 13:37
