Home > Forums > Software User Forums > SU2
finitedifferences.py script in SU2 v7
Old   February 5, 2020, 16:00
Default finitedifferences.py script in SU2 v7
cfdjetman
cfdjetman is on a distinguished road
I am trying to use the finitedifferences.py script in SU2 v7.0 to compare the gradient results to those from adjoints. I am using this tutorial "https://github.com/su2code/su2code.github.io/tree/master/Turbulent_2D_Constrained_RAE2822" as a test case to compare the results.
Note I added a finite difference step size before running this script.
I get the following error
No such file or directory: work_dir/FINDIFF/flow.meta
I see the flow.meta file in the work_dir, not the FINDIFF folder.
How do I correct this?
Thanks
cfdjetman is offline   Reply With Quote
Old   January 13, 2021, 07:37
Ranjan
Ranjan is on a distinguished road
Hi
I have been facing the same issue. I have tried copying the flow.meta from the direct solution sub-directory. Not sure if this is the right way.
Ranjan is offline   Reply With Quote
Introducing SU2 International Developers Society (IDS) fpalacios SU2 News & Announcements 1 June 17, 2019 22:38
Split connectors at their intersection FOUAD12 Pointwise & Gridgen 3 October 8, 2018 10:42
Running SU2 Pyhton Script in Parallel with PBS Torque andromeda91 SU2 1 October 20, 2014 14:25
Official release of SU2 V3.0 and SU2 Educational V1.0 fpalacios SU2 News & Announcements 2 January 22, 2014 05:28
Welcome to the Stanford University Unstructured (SU2) forum! economon SU2 0 January 7, 2013 02:48
