Home > Forums > Software User Forums > SU2
Changing the number of significant figures in surface files written by SU2_DEF
Old   February 10, 2015, 04:22
Question Changing the number of significant figures in surface files written by SU2_DEF
Zen
Zeno
Zen is on a distinguished road
Hello everyone,
is there a way to change the number of significant figures in the files created by SU2_DEF? (Surface_Grid.plt, Surface_Grid.stl, Volumetric_Grid.plt)
I have noticed the number of significant figures of the .su2 mesh file is much larger than that for the above mentioned files.
Thanks,
Z
Zen is offline   Reply With Quote
Old   February 11, 2015, 13:04
hlk
Heather Kline
hlk is on a distinguished road
Originally Posted by Zen View Post
Hello everyone,
Thanks,
Z
Thanks for your question.
I think this can be changed in the output_structure.cpp file. (this will require much searching for the appropriate lines re-compiling the code)
hlk is offline   Reply With Quote
Old   February 16, 2015, 04:25
Zen
Zeno
Dear Heather,
Thank you for your reply. I found out the specific line to change is in output_tecplot.cpp, under the voice "Tecplot_File.precision(###)", where ### is the number of significant figures you want to use.
Best wishes,
Z
significant figures, su2_def
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
