Moving wall- Different rotation rate (config between result) |
April 26, 2015, 23:00 |
Moving wall- Different rotation rate (config & result)
AAA
Rep Power: 11 |
Hi everyone,
I am trying to solve spinning cylinder problem for compressible flows. So I added GRID MOVEMENT option to config file. My option about movement is here. GRID_MOVEMENT= YESBut the following result is returned. 185 ------------------------------ Begin Solver -----------------------------Why are diffrent rotation rate of option file(8572.032) and results file(29.805)? Last edited by cfdkid; April 27, 2015 at 08:06. |
April 27, 2015, 11:50 |
#2 | |
Frederik
Faced this problem as well when I was investigating the grid deformation features. I'm assuming the moving walls are similar.
Hope that helps. |
movingwallvelocity |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
moving wall settings | Nikolaos | FLUENT | 0 | September 20, 2006 06:18 |
moving wall BC problem | Sourabh | Main CFD Forum | 1 | August 8, 2006 07:47 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
