Home > Forums > Software User Forums > SU2
Diverging Tutorial: "Optimal Shape Design of a Rotating Airfoil"
Old   April 17, 2015, 16:37
Default Diverging Tutorial: "Optimal Shape Design of a Rotating Airfoil"
Clancy Umphrey
Clancy is on a distinguished road
I have been familiarizing myself with SU2 by going through the test cases outlined in the User Tutorials documentation. All the tutorial cases ran correctly for me until I got to "Optimal Shape Design of a Rotating Airfoil":
TestCases/optimization_euler/rotating_naca0012
The direct solution begins to diverge after a few iterations and eventually terminates:
!!! Error: SU2 has diverged. Now exiting... !!!
The only case I can get to run without any errors in TestCases/optimization_euler/ is steady_inverse_design. I thought I would check with the SU2 community to see if I am the only one experiencing this issue. My installation of SU2 3.2.9 and TestCases are fresh from GitHub as of 04/15/15. I will be glad to give any further information about my configuration if needed. Thanks!
Clancy is offline   Reply With Quote
Old   April 23, 2015, 18:40
hlk
Heather Kline
hlk is on a distinguished road
Please see the related github issue:
https://github.com/su2code/SU2/issues/167
If you subscribe to the github notifications for that issue you will get an email when it is fixed.
hlk is offline   Reply With Quote
Old   April 24, 2015, 13:18
Clancy Umphrey
Thank you very much for pointing this out!
[DesignModeler] Rotating an imported part in Design Modeler mikko ANSYS Meshing & Geometry 2 November 30, 2015 00:23
Unsteady Adjoint Shape Design EMolina SU2 4 August 26, 2013 18:19
Error in Tutorial-Optimal Shape Design of a Fixed Wing cfdbooks2008 SU2 Shape Design 10 January 29, 2013 09:10
Problem with optimal shape design test case--Windows Error 183 Fang-SIAMM SU2 Shape Design 2 January 28, 2013 15:41
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
