Home > Forums > Software User Forums > SU2
How to compile only the modified files?
Old   September 9, 2019, 21:09
Default How to compile only the modified files?
Aman uz zaman Baig
aman_baig is on a distinguished road
I am starting to add some capabilities to SU2. If I use 'make install' it detects the files that have been changed and recompiles only them. The problem is even then the compilation can take many minutes to complete. Is there a smarter way to make this even faster?
aman_baig is offline   Reply With Quote
Old   September 10, 2019, 02:47
atelcikti1's Avatar
atelcikti1 is on a distinguished road
There is no better way rather than make install or make. If you make small change ie. in solver class which is on the top level, it will not change lots of file so it will take less time comparing to changing transport model which affects lots of classes. If you dont need automatic differentiation just compile without AD flag, it will save severe type according to my previous experience.
atelcikti1 is offline   Reply With Quote
development, make, recompile, su2
How to open old mesh cmdb files in ANSYS CFX v13.0 ? Sudharshani CFX 2 May 12, 2013 22:13
Compiled library vs. inInclude Files, DSMC solver crashes after run GPesch OpenFOAM Programming & Development 8 April 18, 2013 07:17
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
Problems with result files Kasper CFX 5 December 14, 2006 02:41
