Home > Forums > Software User Forums > SU2
CA much lower than reasonable.
Old   February 12, 2016, 08:49
Default CA much lower than reasonable.
Brittany
bmay is on a distinguished road
I am working on a case that is giving me answers I don't believe. The CFx value I'm getting out of SU2 is about 2.6. Using the rule of thumb of a Cd value of ~2 and calculating the CFx value given the largest cross-sectional area and Sref values, the Cfx should be closer to 13. Can you please take a look at my input file and see if there is some glaring error that I'm missing?
Thank you.
bmay is offline   Reply With Quote
Old   February 12, 2016, 20:41
Francisco Palacios
fpalacios is on a distinguished road
The input file seems OK. But, if I were you, I would run it without Multigrid. Could you please post the convergence history and some pictures of the grid? Have you check the y+?
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   February 13, 2016, 09:12
Brittany
My y+ values should be ok. I plotted it out in Paraview, and got values of 0.4 to 26 or so. Unfortunately I can't post pictures of the grid at this time. I will try without multigrid.
Thank you
Old   February 13, 2016, 10:07
Francisco Palacios
Please remember that SA requires a y + <1.0 on the surface. a convergence plot would be useful.
Best,
Francisco
What's happening to my solution for lower relaxation factor casesam OpenFOAM Running, Solving & CFD 3 October 22, 2015 01:25
Temperature lower than possible in closed domain Czarulla Main CFD Forum 1 January 15, 2015 05:01
[snappyHexMesh] upper and lower patch for a 0_thick Membrane in a wind tunnel hfs OpenFOAM Meshing & Mesh Conversion 7 October 15, 2013 16:41
snappyHexMesh: cell lower corner instead of cell centre andrea.pasquali OpenFOAM Programming & Development 4 February 11, 2013 06:22
Lower heating value Andrea Siemens 2 July 30, 2007 07:19
