January 30, 2016, 06:15 |
Extrusion through die
Hi all, I'm very new in CFD and I have a needs: calculate the amount of fluid in an outlet when the fluid is extruded through a die.
The fluid is very like the plastiline. Can I use SU2 to simulate this problem domain? My intent is to realize an application, that permit to simulate a very specified problem domain, so I need to implement the CFD solver engine in my software, can i achieve this with SU2? Thanks. |
February 8, 2016, 21:48 |
Francisco Palacios
Rep Power: 15 |
The problem that you are describing requires a CFD solver for non-newtonian fluids (ketchup, gum, magma, toothpaste, etc) where the viscosity depends on the shear rate. SU2 is mainly for newtonian fluids... But not everything is lost :-) If you have a research project, the implementation os a non-newtonian flow solver is a project by itself and SU2 is a outstanding platform to implement new Partial Differential Equations solvers. Best, Francisco |
die, extrusion |
Difficult ICEMCFD question: Extrusion | Walter | CFX | 11 | April 19, 2011 02:22 |
Question about calibrator in extrusion | Ramin | FLUENT | 0 | August 24, 2004 08:39 |
Design of calibrator in Extrusion process | Srinivasa Rao Vaddiraju | FLUENT | 0 | January 31, 2004 16:57 |
Design of calibrator (or sizing tool)for extrusion | Srinivasa Rao Vaddiraju | Main CFD Forum | 0 | January 31, 2004 16:43 |
Extrusion Modeling | Elliot Schwartz | Main CFD Forum | 1 | September 11, 1998 19:08 |
