Home > Forums > Software User Forums > SU2
Volume integration of solution variable
Like Tree1Likes
  • 1 Post By fpalacios
Old   February 8, 2016, 15:01
Default Volume integration of solution variable
Anonymous
maero21 is on a distinguished road
Hi!
I need to compute a volume integral over the computational domain (for now a 2D airfoil). Specifically, I need to find {\int \int - x \nabla\cdot V dx dy}.
Now I could not find any built-in capability to do so, so I have to implement it myself.
Could you please give some advice on best way of doing that? My guess is that I can reuse some parts of the current code where the residuals are being computed.
Thanks!
maero21 is offline   Reply With Quote
Old   February 13, 2016, 10:05
Francisco Palacios
fpalacios is on a distinguished road
Hi!
In this case my recommendation is to implement the formula at the level of the solver class. For example, dealing with Euler equations, you can use
void CEulerSolver::Postprocessing(CGeometry *geometry, CSolver **solver_container, CConfig *config, unsigned short iMesh) { } in solver_direct_mean.cpp that it is empty.
To find the name of the variables, it is useful to take a look at other well known subroutines like
void CEulerSolver::Upwind_Residual(CGeometry *geometry, CSolver **solver_container, CNumerics *numerics, CConfig *config, unsigned short iMesh).
In your particular case you will need something like
unsigned long iPoint;
su2double Area, dvx_dx, dvx_dy, dvy_dx, dvy_dy, x;
for (iPoint = 0; iPoint < nPoint; iPoint ++) {
Area = geometry->node[iPoint]->GetVolume();
x = geometry->node[iPoint]->GetCoord(0);
dvx_dx = node[iPoint]->GetGradient_Primitive()[1][0];
dvx_dy = node[iPoint]->GetGradient_Primitive()[1][1];
dvy_dx = node[iPoint]->GetGradient_Primitive()[2][0];
dvy_dy = node[iPoint]->GetGradient_Primitive()[2][1];
// The formula should be computed here
// a simple cout will output the result
Thanks for using SU2,
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   February 28, 2016, 19:39
Anonymous
Hi Francisco,
Thanks for your answer. However, if I use this, it computes it every MG iteration, so I moved it to output_structure.cpp.
Regardless of that, the gradients always return zero. Where are the velocity gradients actually computed/which function should I call for them?
I wrote the function
 void COutput::CompDoubletCirc(CGeometry ***geometry,
		CSolver ****solver_container,
		CConfig **config,
		unsigned short val_iZone, unsigned long iExtIter)
where the main loop is this (note that kappax is not computed correctly now, but I want to see whether any of the derivatives is nonzero -- I have also tested them separately):
for (iPoint = 0; iPoint < geometry[val_iZone][FinestMesh]->GetnPoint(); iPoint ++) {
			Area 	= geometry[val_iZone][FinestMesh]->node[iPoint]->GetVolume();
			x 		= geometry[val_iZone][FinestMesh]->node[iPoint]->GetCoord(0);
			dvx_dx = solver_container[val_iZone][FinestMesh][FLOW_SOL]->node[iPoint]->GetGradient_Primitive()[1][0];
			dvx_dy = solver_container[val_iZone][FinestMesh][FLOW_SOL]->node[iPoint]->GetGradient_Primitive()[1][1];
			dvy_dx = solver_container[val_iZone][FinestMesh][FLOW_SOL]->node[iPoint]->GetGradient_Primitive()[2][0];
			dvy_dy = solver_container[val_iZone][FinestMesh][FLOW_SOL]->node[iPoint]->GetGradient_Primitive()[2][1];
			// Compute doublet strength (method 1)
			// 		\kappa_x = \int \int x \nabla \cdot V dA
			kappax = kappax + dvx_dx + dvx_dy + dvy_dx + dvy_dy; // Area*x*(dvx_dx + dvy_dy);
And I call this function in SU2_CFD.cpp with
 output->CompDoubletCirc(geometry_container, solver_container,
                  config_container, ZONE_0, ExtIter);
Thanks!
Old   February 28, 2016, 20:08
Francisco Palacios
I see...
Please notice that the gradients are computed in
void CEulerSolver::Preprocessing(CGeometry *geometry, CSolver **solver_container, CConfig *config, unsigned short iMesh, unsigned short iRKStep, unsigned short RunTime_EqSystem, bool Output) {
using
SetPrimitive_Gradient_GG(geometry, config);
or
SetPrimitive_Gradient_LS(geometry, config);
If you look at the code, SU2 doesn't compute gradients for centered schemes like JST. Are you running JST?
If you want to be sure that you have computed the gradients maybe you can call the subroutine
solver_container[val_iZone][FinestMesh][FLOW_SOL]->SetPrimitive_Gradient_GG(geometry, config);
just before running your code.
Best,
Francisco
maero21 likes this.
Old   February 28, 2016, 23:40
Anonymous
Awesome, that was exactly the problem, I was using JST and the gradients weren't being computed.
Thanks!
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
UDF solution variable for time-averaged mass frac? A. S. FLUENT 0 May 14, 2007 16:44
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
