Forces calculation in hypersonic Mars entry simulation |
April 13, 2016, 22:20 |
Florian Nguyen
Rep Power: 10 |
Hello to you friends,
I am usually more of an OpenFOAM user but I was recently proposed to work on a atmospheric entry simulation. As OpenFOAM is not suited for hypersonic regimes, I consider using SU2 on a Mach number ranging subsonic to 10. My goal is to determine aerodynamic coefficients at various Mach number and density conditions. I am assuming a zero angle of attack configuration and my body has axial symmetry. I can generate my surface mesh for the body that I am studying, and I think I can deal with most of the .cfg file too, but how I to post-process my results and extract the data that I need is still unclear to me. Any of you guys would happen to have any tip or piece of advice for me? Thanks for your time, Florian |
May 26, 2016, 15:09 |
#2 | |
Heather Kline
Rep Power: 13 |
With tecplot output the volume flow output is output in a file called flow.dat, the surface information is in surface_flow.dat which has the surface specified by marker_plotting. File extensions will change for paraview output. |
hypersonic flow simulation | tamjid | FLUENT | 2 | March 26, 2010 05:49 |
hypersonic flow simulation | tamjid | Main CFD Forum | 1 | September 1, 2008 23:46 |
Hypersonic Flow Simulation | tamjid | FLUENT | 0 | September 1, 2008 15:12 |
forces calculation | Chien | CFX | 9 | June 23, 2005 11:45 |
Hypersonic Nonequilibrium Simulation | David Shkval | FLUENT | 0 | April 4, 2002 21:15 |
