Home > Forums > Software User Forums > SU2
v4.2.0 diverges with 32 processors but converges with 16. v4.0.0 worked with 32
Prev Previous Post   Next Post Next
Old   July 6, 2016, 00:27
Default v4.2.0 diverges with 32 processors but converges with 16. v4.0.0 worked with 32
Andrew
asthelen is on a distinguished road
I have used SU2 version 4.0.0 a lot in the past, and recently I installed version 4.2.0. When testing out the newer one, I ran into some issues with # of processors causing divergence.
I used a mesh and solver settings I had recently used for a v4.0.0 simulation (which worked fine on a cluster when using 32 processors). Everything seemed fine when running it on my desktop with 6 processors, but when I ran it on the cluster with 32 processors it diverged. Then I tried running it twice more using 16 and 6 processors. Both worked, although the convergence history values were slightly different. I did try building v4.2.0 using a different MPI implementation too (Intel rather than mpich), which also diverged when using 32 processors but had slightly different convergence history values.
Is anyone familiar with this issue? In the past I have solved similar issues by adjusting MG settings, but it seems odd that different SU2 versions with the same solver settings and mesh would behave so differently. I also don't understand why different mpi implementations (Intel, mpich) give slightly different convergence history values.
Thanks in advance for any input.
asthelen is offline   Reply With Quote
convergence issues, divergence, mpi, number of processor cores, version
Cd or drag coeeficient converges and then diverges vitocorleone OpenFOAM Running, Solving & CFD 3 November 26, 2015 13:43
icoFoam diverges when simpleFoam converges leizhao512 OpenFOAM Running, Solving & CFD 2 September 11, 2015 15:02
Same SimpleFOAM Case converges with openFOAM 2.1 but diverges with openFOAM 2.0.1 alsdia OpenFOAM Running, Solving & CFD 3 October 22, 2012 11:25
diverges with RSM, converges with k-e ares Main CFD Forum 1 May 27, 2012 16:43
converges first then starts to diverges! why? nenazarian FLUENT 1 April 19, 2012 04:07
