Home > Forums > Software User Forums > SU2
Connectivity problem with grids created using gmsh
Old   April 17, 2017, 10:27
Default Connectivity problem with grids created using gmsh
Shashank Srivastava
shank19 is on a distinguished road
I get the following error when I used a 3-D mesh created using gmsh
"The surface element (0, 65622) doesn't have an associated volume element"
Can you tell me what this error means? I understand that the connectivity is a problem but don't know what to do. The mesh file format is OK.
shank19 is offline   Reply With Quote
Old   May 10, 2017, 05:29
Tim Albring
talbring is on a distinguished road
Try to create physical volume along with the physical surfaces.
talbring is offline   Reply With Quote
Old   May 10, 2017, 05:34
Shashank Srivastava
I have created physical surfaces and volumes withing gmsh by extrusion.
I assume that's what you mean by physical volumes. Please correct me if I am wrong.
Thanks!!
Shashank
Old   May 10, 2017, 08:54
Alberto Pizarro
AlbertoPi is on a distinguished road
You have to add a physical tags to the surfaces you want to add boundary conditions. The lateral surfaces of the extruded volume are not desirable in many cases. And also the extruded volume.
For example:
num[] = Extrude {0,0,1} { Surface{1}; Layers{10}; };
Physical Surface {"boundary"} = (num[]);
Physical Volume {"fluid"} = (num[]);
The variable "num" would contain the surface of the top of the extrusion as num[0], the floor of the extrusion as num[1], and the lateral surfaces of the extrusion as num[2,3...].
If you have more than one surface to extrude, the surfaces corresponding to the second extrusion are stored after the last lateral surface of the first extrusion in num[]. For example, if the first surface has 3 edges, the top of the second extrusion is in num[4].
I hope it can help you.
AlbertoPi is offline   Reply With Quote
associated volume element, gmsh files
[Gmsh] having difficulties with easy GMSH periodics problem Jack001 OpenFOAM Meshing & Mesh Conversion 0 November 22, 2016 07:51
FLUENT boundary condition problem with gmsh EIvb FLUENT 0 April 30, 2013 07:45
[Gmsh] Gmsh 3d meshing problem rafamusura OpenFOAM Meshing & Mesh Conversion 2 March 20, 2013 04:31
boundary conditions problem with mesh created in Icem darazsbence CFX 3 February 24, 2013 04:02
problem related to staggered grids zhu Main CFD Forum 10 October 27, 2001 22:30
