Home > Forums > Software User Forums > SU2
Warning! Invalid NRBC input!
Old   June 22, 2017, 08:26
Default Warning! Invalid NRBC input!
Alberto Pizarro
AlbertoPi is on a distinguished road
I need to apply a surface with a suction boundary condition on an airfoil. I tried using MARKER_OUTLET, but the static pressure is not enough to control the suction flow.
I'm trying MARKER_NRBC adding the flow direction. I'm using the next format:
MARKER_NRBC = ( marker, TOTAL_CONDITIONS_PT, Total Pressure, Total Temperature, Flow dir-x, Flow dir-y, Flow dir-z)
But when the solver begins, it returns:
"Warning! Invalid NRBC input!"
And if I use this other:
MARKER_NRBC = ( marker, STATIC_PRESSURE, Static Pressure, 0.0, Flow dir-x, Flow dir-y, Flow dir-z)
The solver works but diverges in few iterations.
Anyone knows if this conditions work right?
Thanks.
Alberto Pizarro
AlbertoPi is offline   Reply With Quote
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 10:05
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 10:20
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
