Input to run unsteady simulations with external files for mesh motion |
September 1, 2017, 12:10 |
Renato R Medeiros
I would ask you how to run an unsteady simulation with dynamically deforming meshes using the surface grid positions from external files. For the steady case, I run SU2_DEF using my config file and the “mesh_motion.dat” file and it generates the deformed mesh, but I don’t know how to input a different mesh motion file for each time step in unsteady simulations using SU2_CFD. I’ve tried to append numbers like “mesh_motion_013.dat” but that doesn’t work. Could someone help me on that? Thank you so much in advance! |
external mesh, input file, unsteady |
interDyMFoam, problems in mesh motion solutor run in parallel | DLC | OpenFOAM | 11 | December 11, 2012 02:20 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 10:46 |
batch file script to run unsteady flow (les) | andi | FLUENT | 0 | April 20, 2004 03:50 |
Procedure to run unsteady simulation? | STN | Main CFD Forum | 2 | February 16, 2002 04:37 |
