Supersonic flow with chemical reactions for validation |
May 20, 2017, 12:38 |
TWB
Rep Power: 19 |
I am trying to simulate a case of supersonic flow with chemical reactions for validation. It is based on the problem by Powers and Aslam (2006, Exact Solution for Multidimensional Compressible Reactive Flow for Verifying Numerical Algorithms). It is about supersonic irrotational flow of an inviscid calorically perfect ideal gas, which undergoes a one-step, irreversible, exothermic, zero activation energy reaction as it passes through a straight shock over a curved wedge. I read that in older versions, there's the TNE2_EULER and TNE2_NAVIER_STOKES but I can't find any example or info in SU2 5.0. Can anyone help? |
April 29, 2018, 21:22 |
#2 | |
Heather Kline
Rep Power: 13 |
These capabilities are not included in the current version of SU2. The old branches still exist - search 'TNE' under the branches on the github repository.
However, this is not being maintained and newer configuration files will not work. Quote:
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Chemical Reaction in continuous flow | Piba | FLUENT | 0 | July 14, 2015 04:47 |
back pressure at exit for supersonic flow | BigFrank | FLUENT | 6 | April 24, 2014 15:13 |
Supersonic flow over an airfoil. FLUENT Lift don't match up with Shock Expansion Tech | enriccasas | FLUENT | 1 | August 21, 2013 06:43 |
Flow in Supersonic MHD Channel | Antanas | CFX | 6 | February 13, 2012 14:49 |
