Home > Forums > Software User Forums > SU2
SU2 File Format
Old   December 26, 2017, 10:38
Default SU2 File Format
Melando is on a distinguished road
Dear CFD community,
I have a question regarding the specification/implementation of the marker elements in the SU2 text file.
According to the wiki:
http://https://github.com/su2code/SU2/wiki/Mesh-File
The node index numbers are the indices used for specifying the connectivity information for elements....
For each boundary, the connectivity information is given which is based off of the same node indices given above.
With that in mind I implemented a converter to SVG and found some strange boundary shapes in some SU2-files in the Master branch of the TestCases repository. When I do not use the supplied index in the last column for the nodes, but instead use their position in the list as index, I get a shape as expected. I did not dig into the source code of SU2_CFD but maybe this should be clarified before relying on results for these that SU2-files.
Any ideas ?
Melando is offline   Reply With Quote
boundary definition, su2 file format
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 21:03
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
