Home > Forums > Software User Forums > SU2
Animating the Laminar Cylinder Tutorial
Old   November 28, 2017, 19:26
Default Animating the Laminar Cylinder Tutorial
Adam Freund
ABF31330 is on a distinguished road
Hi all,
I've run into a snag in my attempts to learn SU2. I have no difficulty running the tutorials provided but I noticed the laminar cylinder tutorial does not produce enough recorded iterations to make an animation. How might I tweak the settings of the .cfg file so that I can create an animation? Also, if someone could direct me to material that will increase my understanding of CFD/DFT simulation I would be very grateful. Thanks in advance!
Adam
ABF31330 is offline   Reply With Quote
Old   December 19, 2017, 05:08
singsong is on a distinguished road
Hi Adam,
Are you running the simulation steady state? If you run the simulation unsteady then usually SU2 will output files after a set number of user defined iterations which can be used to create an animation.
singsong is offline   Reply With Quote
animation, laminar cylinder, su2
Lift Cylinder in Liquid using ANSYS MikeShuo Main CFD Forum 0 October 24, 2016 01:46
Cylinder vortex shedding (3D) Apocolapse STAR-CCM+ 2 April 3, 2014 20:33
flow over a cylinder, turbulent and laminar Chetan Kadakia FLUENT 27 December 8, 2012 05:08
Transient Laminar Flow over a circular cylinder bababanamzdaalma Main CFD Forum 2 March 1, 2012 12:37
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 9, 2008 23:02
