February 19, 2018, 16:53 |
Axis-symmetric flow
Savio Poovathingal
Rep Power: 8 |
I am using SU2v5 (Raven) and trying to run axissymmetric flow. Based on posts over 2 years ago, I use AXISYMMETRIC = YES but I didn't find this option in config_template.cfg that was available with this distribution. There are no print messages that point to an axis-symmetric flow. I wanted to know if this option is okay or is the line AXISYMMETRIC = YES being ignored? Thanks, Savio |
February 22, 2018, 06:23 |
Rep Power: 13 |
Hi Savio, you should find a confirmation of such setting in the config_SOL.cfg and config_CFD.cfd generated when you launch the simulation.
A complete list of input parameters can be found in the config_template.cfg file in the main SU2 folder. I hope it helps. |
February 24, 2018, 11:51 |
Francisco Palacios
Rep Power: 15 |
Hi Savio, there have been numerous improvement in the axisymmetric capability. If I were you I would use the latest version v6.0.
In principle the only required flag is AXISYMMETRIC = YES and be sure that the axis is at y=0 and you are using for the axis Euler or symmetry BC. By the way, if you are thinking on developing SU2, it would be a good idea if you take a look at the new SU2 IDS (www.su2devsociety.org). Best, Francisco |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Pressure variation across flow axis | SmallCFD | FLUENT | 0 | August 25, 2016 12:21 |
proper macro for axis symmetric problem | ayousefi | Fluent UDF and Scheme Programming | 0 | February 24, 2014 09:40 |
Reversed flow in Vertical axis wind turbine | Anonymized_JL1 | FLUENT | 2 | April 11, 2012 03:13 |
