April 19, 2018, 15:01 |
transition modeling in compressible regime
mike
Rep Power: 14 |
Dear All;
Hi. I have two questions using SU2 version 6. 1- Can SU2 B-C transition model predict transition in compressible flow? Any solved problem? As in SU2 tutorial transition folder, all of the three available cfg files (flat plate, E387) are incompressible. I have tried to perform over these grids in compressible regime, but no transition occurs at the same Re which predicted transition well in incompressible flow. 2- Rigid motion of grid seems not to work in incompressible regime. Any idea to investigate transition at Re=400k over a moving body which needs rigid motion? Thanks in advance. |
April 23, 2018, 07:05 |
C
Rep Power: 13 |
You can use B-C transition model for compressible flow. You may check this paper http://journals.sagepub.com/doi/10.1...54406217743537 |
April 23, 2018, 09:47 |
Alberto Pizarro
Rep Power: 10 |
Grid motion doesn't appear on incompressible solver code.
I tried the B-C model with compresible flow and it works. Maybe your laminar regions is too small. |
Laminar-to-turbulent transition modelling using SST and SST Gamma Theta models | ttu004 | CFX | 3 | June 13, 2014 06:43 |
transition SST, transition happening near trailing edge of blade | gholamghar | FLUENT | 5 | October 4, 2013 04:16 |
what can say about separation modeling of compressible flows in OF? | immortality | OpenFOAM Running, Solving & CFD | 0 | May 5, 2013 21:36 |
transition regime modelling.. | sriram g s | FLUENT | 0 | June 12, 2007 05:07 |
to LANGTRY ROBIN :help, hypersonic transition SST | ben akih | CFX | 0 | September 21, 2006 04:59 |
