Attempt to simulate compressible flow in a diffusing S-Duct |
May 26, 2019, 12:43 |
Alex Landsberg
Hello, respected community.
I am trying to simulate with SU2 the compressible flow in a S-Duct (test case of S-Duct of Wellborn - see paper by Harloff et al. in https://ntrs.nasa.gov/archive/nasa/c...9920024502.pdf ). mesh_wellborn.PNG I assign boundary conditions as follows: 1) inlet (entry to S-Duct): INLET_TYPE= TOTAL_CONDITIONS MARKER_INLET= ( inlet marker, total temp, total pressure, flow_direction_x, flow_direction_y, flow_direction_z ) 2) outlet (exit from S-Duct) MARKER_OUTLET= ( outlet marker, back pressure (static) ) 3) Inner wall of S-Duct - Navier-Stokes adiabatic wall boundary MARKER_HEATFLUX= ( inner_wall_marker, 0.0 ) Numerical method - ROE scheme, limiter of Venkatakrishnan = 0.5, CFL = 0.5. As a result, the calculation does not converge and the condition of mass flow conservation is not satisfied between the entry and exit planes. In addition, at some iteration number, the solver gives a warning: "There are XXX non-physical points in the solution". In case of use Euler wall boundary, the calculation converges and the condition of mass flow conservation is achieved. Maybe someone faced a similar situation - Does anybody have some ideas why the RANS Spalart-Allmaras SU2 diverges for such a standard tes-case for internal flow ? Any help will be kindly appreciate since currently we are unable to resolve that issue. Sincerely yours, Alexander |
May 30, 2019, 19:20 |
Nitish Anand
Rep Power: 9 |
Hey Alexander,
I usually ramp the back-pressure for supersonic turbomachinery cases, maybe you can try that out. Thanks, Nitish |
back pressure, boundary conditions, inlet and outlet, internal flow |
analyzing the temperature of fliud (air) flow inside an underground duct. | arshbunny | CFX | 9 | April 3, 2014 08:52 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
urgent help needed with 2d compressible flow | James | FLUENT | 2 | June 20, 2007 04:22 |
how to simulate compressible swirling flow? | ravi | FLUENT | 2 | May 22, 2007 08:36 |
Compressible duct flow | Masoud | Main CFD Forum | 0 | December 20, 2005 13:38 |
