April 23, 2018, 17:14 |
Monitoring Mass Flow Rate
Umut Can
Rep Power: 13 |
Hi everyone,
How can i monitor mass flow rate, total pressure and any other flow quantity at the pressure outlet boundary. Thanks in advance. |
April 29, 2018, 20:35 |
Heather Kline
Rep Power: 13 |
To output averaged quantities at an outlet, set MARKER_MONITORING to the marker the defines the outlet, and set MARKER_ANALYZE_AVERAGE to the type of averaging you want (area-averaged or massflux-averaged).
(Using version 6.0) |
May 1, 2018, 09:29 |
#3 | |
Umut Can
Rep Power: 13 |
It actually works with no problem. However, it prints the related flow quantities according to the WRT_SOL_FREQ value. What I really need is to observe and investigate change in flow quantity at outlet in every iteration like residual. Is it possible to do that? Thanks again. |
May 1, 2018, 22:10 |
Heather Kline
Rep Power: 13 |
I think that it should be output in the history file - it sounded like you were referring to the console output.
May 5, 2018, 08:38 |
Umut Can
Rep Power: 13 |
Thanks a lot
February 17, 2019, 18:17 |
Brandon Gleeson
Rep Power: 8 |
Hoping to resurrect this thread, as I'm still not able to get the mass fluxes at the inlet/outlet of my internal flow simulation to write to the history.csv file.
I have the following settings defined: % Marker(s) of the surface where the functional (Cd, Cl, etc.) will be evaluatedThe WRT_SURFACE setting successfully added the inlet and outlet surface values to the history.csv file, but only the lift/drag/force/moment coefficients which aren't relevant in this case. Does anybody know of a way to add the boundary or surface total mass flux to the history.csv file, or would this require a change to the source code? Thanks! CSMDakota |
boundary condition with pressure AND mass flow rate | tsi07 | FLUENT | 3 | April 14, 2022 12:32 |
Access inlet mass flow value (target mass flow rate) | YCarv | Fluent UDF and Scheme Programming | 2 | April 1, 2018 08:09 |
Higher mass flow rate at outlets as compare to inlet | Ahmed Saieed | FLUENT | 0 | April 3, 2016 23:08 |
Calculating mass flow rate at multiphase flows | Kuslo187 | OpenFOAM Post-Processing | 1 | August 21, 2015 18:11 |
mass flow rate in DPM steady tracking | Roule | FLUENT | 4 | June 1, 2015 10:44 |
