Home > Forums > Software User Forums > SU2
How to set periodic boundary
Old   July 11, 2019, 21:31
Default How to set periodic boundary
Jianming Liu
liujmljm is on a distinguished road
Hi, I am running the SU2-6.2.0 code to test the case of 3D Backward-facing step. Could u please tell me how to set the periodic boundary. Thank u.
liujmljm is offline   Reply With Quote
Old   July 12, 2019, 10:49
na
TKatt is on a distinguished road
currently integrated is only 'spanwise' periodicity. So in case of a 3D backward facing step you would apply the periodic BC to the side walls of the channel, simulating approximately an arbitrary wide channel.
% Periodic boundary marker(s) (NONE = no marker)
% Format: ( periodic marker, donor marker, rotation_center_x, rotation_center_y,
% rotation_center_z, rotation_angle_x-axis, rotation_angle_y-axis,
% rotation_angle_z-axis, translation_x, translation_y, translation_z, ... )
MARKER_PERIODIC= ( NONE )
So for a translational periodicity of e.g. 1.0 in y-direction (say y-coord is your channel width) it would look sth like this
MARKER_PERIODIC= ( left_side, right_side, 0,0,0, 0,0,0, 0,1.0,0 )
or
MARKER_PERIODIC= ( right_side, right_side, 0,0,0, 0,0,0, 0,1.0,0 )
order does not matter there. That is all there is to do, the mesh can stay as is.
Hope that helps,
Tobi
TKatt is offline   Reply With Quote
Old   July 12, 2019, 11:37
Jianming Liu
thank u very much
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Unsteady Periodic Boundary Condition EMolina SU2 0 July 24, 2014 16:16
Radiation interface hinca CFX 15 January 26, 2014 17:11
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
