Home > Forums > Software User Forums > SU2
Blunt body test case
Old   July 13, 2019, 03:38
Default Blunt body test case
Dr. H.K. Narahari
hk.narahari is on a distinguished road
I see a .cfg file for a blunt body at M= 6 in the test cases directory. However, there is no .SU2 (mesh) file for running it. Has the mesh file been re-located somewhere else, if so can someone PL share the location.
Thanks in advance
Narahari
hk.narahari is offline   Reply With Quote
Old   July 13, 2019, 06:01
Default Blunt body
Dr. H.K. Narahari
I located the blunt_91.su2 and ran the code successfully. However, when I created a similar mesh (gmsh --> SU2 format) and tried to run the program stops just before writing. I tried even with 1 iteration but still the same error. I am using the same .cfg file as in the test case (mesh name is changed). I am attaching a screen shot of the error message, any suggestion would be great help.
Thanks,
Narahari
Error when run test case turb_ONERAM mistuning SU2 1 October 3, 2013 02:17
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
Ahmed body test case Farhat FLUENT 4 May 23, 2007 06:42
Ahmed bluff body test case Richard Howard Main CFD Forum 0 February 22, 2000 10:26
