September 16, 2019, 03:37 |
mesh morphing to manually transform a patch
William Tougeron
Rep Power: 15 |
Hi all,
In the config_template.cfg file from SU2 6.2, one can find (line 1069): % - TRANSLATE_GRID ( x_Disp, y_Disp, z_Disp ), as a unit vector % - ROTATE_GRID ( x_Orig, y_Orig, z_Orig, x_End, y_End, z_End ) axis, DV_VALUE in deg. Is it possible to apply this transform only on some patch(es) selected using DV_MARKER, so that other patches stay untouched and the internal mesh is morphed? Best regards, |
September 16, 2019, 05:51 |
Pedro Gomes
Rep Power: 13 |
I believe those are rigid body motions only.
September 16, 2019, 07:45 |
William Tougeron
Rep Power: 15 |
Could do the job using the DV_KIND= SURFACE_FILE approach (cf. tutorial SU2-6.2.0/TestCases/deformation/naca0012). By launching SU2_DEF a first time, it creates some file containing all points of selected patches. Then, one edits this file with desired point coordinates after deformation, then re-launch SU2_DEF. For translation, this is straighforward. For rotation, this needs a bit of scripting to edit the file. Important parameters are also in the "GRID DEFORMATION PARAMETERS" section. I changed the DEFORM_STIFFNESS_TYPE value from INVERSE_VOLUME to WALL_DISTANCE to have cleaner results. Hope this can help some more people. All the best, |
manual, marker, morphing, patch, su2 |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[Commercial meshers] Thin Walls Conversion from Fluent Mesh | Isaac | OpenFOAM Meshing & Mesh Conversion | 1 | March 4, 2016 12:08 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 11:25 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
