Home > Forums > Software User Forums > SU2
Calculate drag in su2 v7.0.0
Old   December 17, 2019, 18:10
Default Calculate drag in su2 v7.0.0
Fabio Michael Bluhm
fabiox8 is on a distinguished road
today I decided to switch from SU2 V6.0.0 to V7.0.0 and a problem occured.
I want to calculate the DRAG (or any other function like LIFT, SIDEFORCE, ...).
With SU2 V6.0.0 I use this python script to get the DRAG:
import SU2
config = SU2.io.Config("inv_ONERAM6_V6.cfg")
config.MATH_PROBLEM = "DIRECT"
config.RESTART_SOL = "NO"
config.NUMBER_PART = 4
config.NZONES = 1  # no multizone simulation
config.EXT_ITER = 1 # just for fast debugging
state = SU2.io.State()
info = SU2.run.direct(config)
state.update(info)
responseValue = SU2.eval.functions.function("DRAG", config, state)
print(responseValue)
However in SU2 V7.0.0 This does not work anymore.
I get this error message:
Traceback (most recent call last):
File "a.py", line 21, in <module>
File "/home/fabio/SU2/SU2_V7.0/bin/SU2/eval/functions.py", line 118, in function
func_out = state['FUNCTIONS'][func_name]
KeyError: 'DRAG'
It seems like info = SU2.run.direct(config) does not contain anything in info['FUNCTIONS'] and therefore SU2.eval.functions.function("DRAG", config, state) can not retrieve any information.
I would be happy to get suggestions on how to solve this problem.
Best
Fabio
fabiox8 is offline   Reply With Quote
Old   December 18, 2019, 10:12
Tim Albring
talbring is on a distinguished road
Hi Fabio,
you have to add the output group "AERO_COEFF" to the history output option.
e.g:
config["HISTORY_OUTPUT"].append("AERO_COEFF")
Regards,
Tim
Developer Director @ SU2 Foundation
Get involved:
talbring is offline   Reply With Quote
Old   December 18, 2019, 16:31
Smile Solved
Fabio Michael Bluhm
Hi Tim,
this works. Thank's a lot!
Now that you explained it to me, I also found the new user guide
Best
Fabio
blackbird, eval.functions, problem, run.direct
How to calculate Cn (normal Drag Co-effiecient) and Ct (tangential drag co-efficient) amianjan FLUENT 0 February 12, 2014 02:00
how to calculate mean value of lift and drag aamer Main CFD Forum 9 December 21, 2010 00:23
does anyone know about using comsol 4.0 to calculate drag force sl424 COMSOL 0 November 13, 2010 22:28
How should we calculate the drag force ?? Thinnapong FLUENT 5 May 4, 2008 13:46
How to calculate the drag force? James CFX 1 April 24, 2008 00:59
