Home > Forums > Software User Forums > SU2
SU2 v7 NOT writing a restart file for Turbomachinery cases
Old   December 25, 2019, 17:14
Default SU2 v7 NOT writing a restart file for Turbomachinery cases
Aman uz zaman Baig
aman_baig is on a distinguished road
I expect a restart file to be generated by running SU2. If I include Turbomachinery markers it is not generating a restart file. I am using the transonic_stator 2D case in the Testcases directory.
The config and mesh files can be found at:
https://mailuc-my.sharepoint.com/:f:...YHkxA?e=SXJov7
One config file has Turbo markers and the other has Turbo markers commented. You just have to run the two config files and see the difference.
This should be very straightforward but the new version v7 has got something wrong with the Turbo markers. It is only throwing a history file out and nothing else.
Any help will be appreciated.
Thanks,
Aman
aman_baig is offline   Reply With Quote
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 14:30
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 11:27
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
