January 22, 2020, 14:54 |
Adding new class, how to compile it?
Aman uz zaman Baig
Rep Power: 10 |
Hi all,
I have added a new class for 1D interpolation in SU2 and I have a new .cpp and .hpp file to include with it. During compilation the compiler does not create the object of my class and gives the following error: solver_structure.cpp.text+0x10d98): undefined reference to `CInletInterpolation::CInletInterpolation(CGeometr y**, CConfig*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, unsigned short, unsigned short, unsigned short, unsigned short)' solver_structure.cpp.text+0x10e87): undefined reference to `CInletInterpolation::~CInletInterpolation()' solver_structure.cpp.text+0x12426): undefined reference to `CInletInterpolation::~CInletInterpolation()' Are there are any files I have to change so that the compiler can see the new files? Thanks, Aman |
January 23, 2020, 09:19 |
Akshay Koodly
Rep Power: 8 |
There should be a meson.build in the src/ directory (for ex, https://github.com/su2code/SU2/blob/...rc/meson.build) where all the .cpp files are listed. Can you try adding your *.cpp file in the corresponding directory (there is a meson.build in all */src directories) and try to compile? Regards. |
January 23, 2020, 09:38 |
Pedro Gomes
Rep Power: 13 |
Hi Aman,
If this relates to your current pull request let's move the conversation to github. Cheers, Pedro |
January 23, 2020, 19:03 |
Aman uz zaman Baig
Rep Power: 10 |
Thanks @akoodlyr for your advice. Let me see if that works.
@pcg - Yes this is related to my PR. I will put questions there if it doesn't get resolved. |
class, compile, su2 |
chtMultiRegionSimpleFoam 3D problem | Lucie | OpenFOAM Pre-Processing | 2 | June 21, 2016 05:23 |
adding new fvm class | danny123 | OpenFOAM Programming & Development | 1 | December 14, 2015 09:53 |
chtMultiRegionFoam, adding a member to an existing class (regionProperties) | romain.h | OpenFOAM Running, Solving & CFD | 1 | October 10, 2012 15:05 |
Can someone PLEASE document the development version installation | bernd | OpenFOAM Installation | 76 | November 14, 2008 21:51 |
Adding new class in version 12 | billy | OpenFOAM Pre-Processing | 1 | October 10, 2005 04:47 |
