Home > Forums > Software User Forums > SU2
How to get the Screen output of SU2 run from terminal into a csv file?
Like Tree1Likes
  • 1 Post By akoodlyr
Old   April 30, 2020, 17:16
Post How to get the Screen output of SU2 run from terminal into a csv file?
Vatsa
vatsa_6 is on a distinguished road
I'm running RANS simulations of golf ball and i would like to plot Drag coefficient vs number of iterations of which the values are being displayed in terminal while running a simulation.
What settings are needed to be changed in config.cfg file in order to get the data output.
Thank you
vatsa_6 is offline   Reply With Quote
Old   May 1, 2020, 06:27
Akshay Koodly
akoodlyr is on a distinguished road
There is a history file written when you run your simulations. You can check the history output section here (https://su2code.github.io/docs_v7/Custom-Output/) to customize your outputs.
Specifically to plot Cd vs iteration you can try
HISTORY_OUTPUT = (ITER, RMS_RES, AERO_COEFF)
Cheers.
vatsa_6 likes this.
akoodlyr is offline   Reply With Quote
data extract, su2
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 14:30
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 05:18
