Home > Forums > Software User Forums > SU2
Numerical method for gradient calculation
Like Tree2Likes
  • 2 Post By pcg
Old   May 29, 2020, 03:44
Default Numerical method for gradient calculation
Peter
jomunkas is on a distinguished road
Are Green Gauss and Weighted Least Squares schemes node or cell based in SU2?
Which would you use for a considerably skewed structural mesh with boundary layers?
Green Gauss is better for high aspect ration cells like in the boundary layer, while Weighted Least Squares are performing better on bad meshes, right?
Syrakos, Alexandros, et al. "A critical analysis of some popular methods for the discretisation of the gradient operator in finite volume methods." Physics of Fluids 29.12 (2017): 127103.
Thanks,
jomunkas is offline   Reply With Quote
Old   May 29, 2020, 05:07
pcg
Pedro Gomes
pcg is on a distinguished road
I use Green-Gauss because it is faster.
WLS is purely node based.
GG requires the values at the faces to be integrated, face values are obtained from averaging the solution at the nodes (SU2 uses a median dual grid, so the faces of the dual control volumes are always halfway between nodes).
bkay and jomunkas like this.
pcg is offline   Reply With Quote
Reference for Convective numerical method: AUSMPLUSUP, AUSMPLUSUP2 dhxlxz SU2 2 June 17, 2019 21:17
Numerical calculation of Cl, Cd, Cm from Cf and Cp mmisu Main CFD Forum 6 April 7, 2014 01:18
3D numerical flow calculation in steam turbine stage mesik FLUENT 0 March 24, 2014 14:35
Numerical calculation of fractional derivatives Hamid Karani Main CFD Forum 1 September 30, 2008 05:51
Solid-Liquid Two Phase Flow Numerical Simulation with the Finite Element Method Qing Hao Main CFD Forum 2 January 8, 1999 23:31
