Error installing SU2 binaries with mpi support on windows |
Bradley Craig
Rep Power: 5 ![]() |
Upon instaling the SU2 binaries with mpi support and installing the required mpi files, I go to run my simulation with mpiexec -n 4 SU2_CFD ...... and 4 instances of SU2 begin in serial.
SU2 works absolutely fine in serial and I have ran a multitude of successful sims in the past this way so I assume theres an error with my mpi installation. Does anyone have any idea what the problem could be? Thanks in advance ![]() |
Pedro Gomes
Rep Power: 13 ![]() |
That is usually caused by a mismatch between MPI versions.
Try to use the exact versions mentioned in the documentation. |
Bradley Craig
Thank you for the reply, I have used MS MPI v10.1.2, which is what is stated for SU2 7.1.0 so it should be fine in this respsect I think.
Do you happen to know of any other things that could cause this problem? Thank you ![]() |
jim
Rep Power: 4 ![]() |
Hello Creg,
I ran into the same problem just like you did, i wonder if you have resolve this problem yet. Thanks, best, JIM GIGI |
mpi parallel, su2, windows 10 |
SU2 Installation for Windows 8 | cacatoire | SU2 Installation | 1 | August 14, 2020 12:07 |
SU2 Installation on Windows 32 bit | niddaas | SU2 Installation | 3 | May 6, 2016 17:03 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
SUPPORT FOR WINDOWS NT PLEASE! | Mr. Lomil | Main CFD Forum | 3 | November 3, 2003 09:11 |
