[Sponsors] | |||||
Ravi
Rep Power: 10 ![]() |
Hello all,
I am currently trying to obtain the plots of and vs. convective time units (non-dimensional) for an airfoil in deep stall (having an angle of attack of 60) using the DDES approach, using the SA turbulence model and a 2nd order numerical scheme (dual-time stepping scheme). I have an issue with plotting the results and comparing them with the ones obtained from experimental data from Swalwell as attached with the comment below. For some reason, when I restart my solution from somewhere in between, there is a mismatch in the residuals that I obtain. This does not seem to make sense from the numerical perspective, as the solution should simply start from where the solver left off. Furthermore, the fluctuations in and seem to have diminished for the given time traces, when there is actually supposed to a significant deviation from a certain mean value for both coefficients. Is this on account of high numerical dissipation in the current scheme?Hoping to hear from you soon. Ravi |
Ravi
Hello all, so as a follow-up to the previous post that I had put up last week, I had found out that this error was due to the fact that I had been plotting the time averaged values of and all this while for this case. I had also run a URANS k- model simulation to compare my results with them. It seems like the DDES model does not have an option of plotting the and values for each time step in the history file. I tried looking under the options of AERO_COEFF, but the history file only seems to be writing the time averaged values for DDES simulations and not for URANS ones, and hence, the fluctuations in and are captured in the latter but not the former. Can someone please help me out with this?I have attached relevant snapshots of the history as well as the configuration files for the two cases with the post for reference. Hoping to hear from the others soon. Ravi |
Pedro Gomes
Rep Power: 15 ![]() |
From your first plot it looks like you are plotting all the inner iterations.
But without more information it is impossible to help. Attach your config, the screen output..., the history file..., otherwise the only people in the world that might understand the problem you are describing are the ones who already had it. |
#4 | |
Ravi
With warm regards, Ravi |
#5 | |
Ravi
As a late update to this, this issue was caused because of the fact that the time-averaged windowing part was turned on, because of which the instantaneous solution remained more or less constant with the number of time iterations. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 09:46 |
| [OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
| [swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 13:41 |
| [swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 14:59 |
| friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
